I'm burning washed, dried, fully converted B100 in my Beckett AFG burner (suntec pump). Adjusted the air down, put in a .65 nozzle, and bumped up the pump pressure to 135 psi. Flame cone is perfect, always starts, no problems but one.
The nozzle drips BD when off which crystalizes and accumulates in the bottome of the gun housing. Anybody figure that one out yet?
dt
'02 VW Jetta
'97 F-250 7.3L Powerstroke
B50 through B100 depending on weather
B100 fired hot water furnace
Location: Connecticut | Registered: 01 June 2006Reply With QuoteEdit or Delete MessageReport This Post
Install a gadget called an "eco valve" from patriotsupply.com in place of the nozzle strainer. It has a spring valve that opens at 135# and closes at 100# when the pump shuts off to prevent nozzle drip. I'm burning B100 in my AFG and have had good results so far.
2005 VW Passat TDI
Beckett AFG HHO burner converted to B100.
"The significant problems that we have cannot be solved with the same level of thinking with which we created them." -Albert Einstein
Location: Maine | Registered: 08 September 2006Reply With QuoteEdit or Delete MessageReport This Post
Thanks alechemist.
I'll check it out.
dt
'02 VW Jetta
