well you going to think Im nuts but search in here for Pinapple. Not sure if you have one or not in your present heater. If not adding one might enhance your burn and reduce chance of your nozzle issue
_________________________ If you believe you can't YOUR RIGHT;
| Location: North Tx | Registered: 23 November 2002 |    |
quote: Originally posted by gonzotto:... I think I may look into some sort of "pineapple." One of my friends is a copper worker. Maybe this would be a good material?
Tread wisely. While Pinapple may help.... watch temps. Just wondering if it will bring higher heats to parts of the heater not intended to reach higher temps. ideas on how to make a Pinapple are in this forum already. Certainly not a copper thing if I recall right.
