I saw this on the news and thought I would put it out there as a warning to others. Apparently the 18 year old boy was cutting into the used peppermint oil drum with some type of power saw to make a BBQ when it exploded... What a tragic accident that never should have happened... ![]() http://www.ottawacitizen.com/h...n/4848686/story.html ___________________________ Simple schematic for a pump and heater control with a high limit Sensor for the biodiesel/glycerin layer | ||
Good post Jon-hopefully will warn others-if only someone could have told him-tragic waste of a life | |||
I picked up a drum that had contained it about a year ago. the drum was missing the 1" bung so I was careful to put that side to teh top in the back of my station wagon for the trip home. The smell of the stuff was overpowering and incredible. I thought the drum must have had a leak so stopped to check but it was fine all the smell was coming from the bit of air circulating through the single small hole! Didn't matter if I had all the windows open or closed, the aroma was enough to bring streaming tears to my eyes. The experience of the trip home was enough to motivate me to wash that drum real well before I cut it and I also put a flexible hose attached to a generator into teh drum to evacuate it of oxygen while I cut the thing. It sure smells nice in limited amounts be seems to be powerful stuff! | |||
Good post Jon, very sad to say the least! What galls me most at this point is this incident continually gets referred to as an accident, accident be damned, this is the result of GROSS negligence on the part of the shop instructor!!! As you know I have been involved in the welding industry for near 50 years, while in the RCAF oil tank welding was a daily occurrence, never ever did one blow up. SAFETY procedures must be followed; tanks must be steamed prior to cutting or welding. Now I know most here don’t have access to steam but we do have cars, evaluate the oxygen from the tank with car exhaust! When the tank is warm to touch it will be safe to work on. keep the exaust flowing for the duration of the work. As mentioned in a previous post it is safer to weld on a full tank than one that is empty, there is some truth to that but it is not something you could pay me to do. I know an someone who was sitting on an empty soap drum that blew up instantly when he tried to cut it with a tourch. The subject of drum and propane tank cutting and welding has been bantered around on this forum many times I shudder at some of the advise that has been given Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. | |||
That is exactly what I said to my wife when I heard the news, that and "he should be in jail"... Truly unbelievable. If the guy was by himself under no supervision and without a clue I could understand it, but for it to be a shop assignment and happen right in the shop class??? This is the place where safe practices are supposed to be learned... ![]() Jon ___________________________ Simple schematic for a pump and heater control with a high limit Sensor for the biodiesel/glycerin layer | |||
Sounds like it wasn't even the boy doing the cutting that died. The project next to him exploded and he took the brunt of it. The boy who was actually building the grill is injured but alive. | |||
Powered by Social Strata |
