Biodiesel homebrewers in the Philippines
I am planning on manufacturing biodiesel to fuel my diesel SUV.
I will be happy to be a part of PI's bioprocessor group. Manoy
Hi Manoy,
Happy to have you on-board. |
count me in. Good luck and may our tribe increase...
pidsmb HTML |
Hello Pidsmb,
Welcome aboard! |
Hindi ako nakatira sa Pilipinas, pero nagho-homebrew ako dito sa Utah, USA. Kung meron kayong tanong tungkol sa pagpro-production, just ask me.
Good to hear that there are Pinoys getting into biodiesel! Welcome! '93 Chevy K3500 w/6.5 turbo, 4x4. 11k miles on bio and counting. '02 Ford F350 4 Door Short-Bed w/7.3 Powerstroke. 7k miles on bio. |
Hello everyone, i'm already making biodiesel since june 2008, but i'm having problem where to get enough supply of used cooking oil, for now I can only get 100 liter a month
Hello Chris,
Thanks for the support. As of now I am only making small batches (1 gallon) until I finished my 55 gallon processor. One challenge though is where to source out good WVO. Best regards, Edwin |
Hello Arvin,
You can try contacting some restaurants in your locality. Be careful though in getting oils with too much FFA's. What I did is that I contracted our company canteen for them to sell to me their WVO. That way, I can get 20 liters per week. |
Yup, that's what i did, I get my WVO from some restaurant, that's where my 100 liter per month supply comes from, but I need more since I can already process 200 to 300 liter at a time, I have a 400 liter processing tank and a 500 liter settling/washing tank, I don't know how much FFA in my oil since I don't titrate my oil
Arvin, how do you make your biodiesel since you dont titrate? Do you do an acid/base process?
Hello Chris
Holy Cow, Arvin! Why make it so dificult on yourself? I cant imagine any reason to do an acid/acid/base/base.
...unless you cant heat your oil for some reason? '93 Chevy K3500 w/6.5 turbo, 4x4. 11k miles on bio and counting. '02 Ford F350 4 Door Short-Bed w/7.3 Powerstroke. 7k miles on bio. |
hello Chris.im new to biodiesel homebrewing..what method do u ususally use in making biodiesel...tnx
Yes chris, I don't heat my oil up to boiling, It would take too much energy, electricity here in the Philippine is very expensive, burning glycerin produces too much fumes, price of char coal is also going up, you can also forget about other form of fuel for heating, I can save a lot more by using more acid that heating up the oil, also I find using more acid better since you can convert more FFA, remember, heating the oil to boiling produces more FFA, which is not very ideal, I'm thinking of buying a centrifuge but for now I still can't afford it even a surplus one
NO NO NO.
You should not heat the oil up to boiling, that is not what I said. (I am not sure if you mean boiling point of water 100 C, or the oil ~225 C). You should heat the oil to somewhere near 55 C. This can be achieved easily and cheaply by leaving a black vessel of oil out in the sun for a few hours. '93 Chevy K3500 w/6.5 turbo, 4x4. 11k miles on bio and counting. '02 Ford F350 4 Door Short-Bed w/7.3 Powerstroke. 7k miles on bio. |
I make my biodiesel like this: 1. Load processor (40 gallon electric water heater) with 25 gallons (95 l) settled, dry oil (mostly canola, some soy). 2. Heat the oil up to 130 F (55 C) while circulating the oil with a clear water pump. 3. Titrate the oil to determine how much KOH to add to the methanol. 4. Mix KOH into methanol (7 gallons [26 liters]), I use a base amount of 8 grams KOH per liter of oil + amount determined by titration. 5. Add methoxide to oil slowly over the space of 20 minutes. 6. Process for 2 hours from the time that all of the methoxide has been added. 7. Move mix to cone-bottomed settling drum. 8. Settle for 8 hours. 9. Drain glycerine and set asside in sealed container for methanol reclamation. 10. Wash with a fine mist of water for 8 hours. 11. Drain all water and any little bit of emulsion out and store in aggregate drum for settling. 12. Dry biodiesel by recirculating from bottom of drum to top while heating and ventilating with a desktop fan. 13. Pump finished fuel through polishing filter, into vehicle or storage drum. '93 Chevy K3500 w/6.5 turbo, 4x4. 11k miles on bio and counting. '02 Ford F350 4 Door Short-Bed w/7.3 Powerstroke. 7k miles on bio. |
Yes chris, I just heat my oil at about 60 C for about 3 to 4 hour to remove a little bit of moisture, I use a small stove fueled by biodiesel, this is also to make the oil thin for better filtering
