Hello Margo
Provided the container the biodiesel is in is open, heating will dry it. Just letting it sit in the sun for a few days works fine. |
I too am new at this and will be brewing soon. I've made a seperate drying tank w/ a blower pipe extending down to the bottom of a 40g elec. hw heater and plan to heat it up to near boiling and blow warm dry air thru it to escape out the vent. My question is how long do I heat/circulate and airate? And how do I know when its dry?
Will |
Not sure how the appleseed type set-up reacts but you might try doing a hot pan test(hpt)first and dry for awhile,after temp hits 150 or so,start time, then do hpt again to see how much drier it is.
Would probably be faster with an open top drum and shower head,heater set-up. Mine dries in about 2hrs.after hitting temp. so maybe 3 hrs total. |
11western....your set-up sounds good...would you be able to post pics of it....I've got to see how this works...
Paul |
http://www.b100wh.com/waterwash.html down near the bottom is the way I used to do it.
Sorry frenchfry1 been busy lately but yeah check biodieselpictures.com look in the equipment pics section.
I'll double check to make sure I put good pics of the inside of the tank and all that. |
