I purchased some Hydrosource soil additive to try in dewatering both WVO and Biodiesel.
I made a nice emulsion of biodiesel and water. I started out with about 300mls of biodiesel milkshake. I made a "tower" out of a old 1 gal water bottle. I cut the bottom out and I drilled a small hole in the cap and put in some coffee filters in it to keep the grains of hydrosource from going anywhere. To the tower I added 1lb of hydrosource which is most likely more than needed. I added the biodiesel milkshake which was at room temperature 85F or so. I had to pass the biodiesel thru the hydrosource about 8 times to be able to see thru the biodiesel. I lost about 60mls of volume and ended up with about 240mls of what appears to be dry biodiesel. As soon as I get a working camera I will try and post some pictures.
I have been keeping it simple and just adding the crystals to the washed bio with some stirring and letting it sit a couple of days or more (up to a week now)...the crystals seem to be picking up some water that way and so far I don't think they are being degraded by long term contact with the ester (but I could be wrong).
