My manometer reads 183mm if I test a sample containing 500ppm of water. If you construct your own carbide manometer you could use this figure as a rough guide but it is much better if you calibrate your apparatus.
Here is how I calibrated my carbide manometer. I began by bringing 2.5 litres of biodiesel up to 125 degrees C and kept it there for 2 hours. Steam stopped rising of the surface after an hour but I wanted to be sure it was completely dry.. Using a clean dry graduated cylinder I measured out a litre and added 2ml of water and immediately put it into a sealed container. This would be my 2000ppm reference sample I then did the same with another litre but this time added half a ml of water. This would be my 500ppm reference sample. I used a new clean 5ml syringe, I was very careful and I wore my closeup glasses, but I reckon this method cant do better than 10% accuracy. However I would be happy with that. All of the following tests were carried out at 16 degrees C (289degrees K) All samples were 100g to maximise accuracy and the vessel was shaken for 5 minutes or until no movement was seen for a minute As a control I tested some of the totally dry bio and got a result of 9mm. This may have been caused by the screwing closed of the cap or it may be a true reading caused by atmospheric moisture in the vessel. I dont know for sure but it is so small a reading it does not really matter. I tested the sample with 2ml per litre or 2000ppm first. The reading was 622mm, The sample with .5ml per litre or 500ppm gave a reading of 183mm. On a A4 page of squared paper I marked off the vertical scale from zero to 3000ppm and on the horizontal scale I marked off from zero to 1000mm. I plotted my two results and drew a straight line through them with a ruler. With this graph I can translate any manometer reading into ppm instantly. |
