Home
Forums
Oil Collection
What % water is a good point to settle and drain vs spra/bubble dry?|
So drum #2 and some various cubies went into the spray drier yesterday evening 7:00ish at 5.8% H2O. Heated to 140F then let settle for 2 hours, drained ~1.5G then heated and sprayed all night.
This morning 10:00ish there was an undetectible water level (using WHW to 260F) RH around 75%, there was also no foamy head developed on this batch. |
40 gallons oil went into the spray dryer last night before bed time from various cubies, both soy and PHO.
Starting H2O was .3%, sprayed over night with no heat, just a fan. This morning there was no detectible H2O in a 450g sample brought to 240F. To be expected at such a low starting %. I have one more full drum to throw in there that has alot of H2O. I'll try to dry that one this week. |
Hi,
I've been following along. I'm no expert, but if this is to become biodiesel, my way of saving time and energy is to mix in 20% raw glycerin for an hour and settle overnight. I do this per batch, not for storage. Brian 1996 K2500 4x4 6.5TD |
Brian,
I'm avoiding the Glycerine pretreat cause I may have to acid/base this oil since it's from several different drums that have been sitting for up to two years. Until I fill a tote, I'm not sure how acidic it is. |
Raining here so I just put the wet drum of oil through my cold upflow barrels. I think that's it for the wet old stuff around here. If I get anymore I'll see what I can find out.
Home
Forums
Oil Collection
