| Location: Southeast Texas | Registered: 12 September 2009 |    |
my god what a fine specimen. they never look like that up here... ------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com
| Location: Northern Colorado, USA | Registered: 26 June 2008 |    |
Test drove the exact model in silver this morning. Too bad there was rust on it... that coupled with needing a valve job, some shocks and a valve cover gasket screwd the pooch. ------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com
Any chance you can get it to central FL?
| Location: Cocoa Beach FL | Registered: 12 September 2005 |    |
member 2009 Sponsor
I have a perfect seat for this car; asking $80 if you pick it up. How many miles on the car? Does the odometer work?
daw
1986 Mercedes 300SDL 2000 Dodge Cummins
| Location: Memphis, TN (kind of) | Registered: 24 January 2007 |    |
