nullThis message has been edited. Last edited by: Neurot, | ||
Jason, FWIW, I think it's cool that you post stuff like this here. Kumar Plocher Yokayo Biofuels Yokayo Biofuels Facebook page .........../ \.............. fueling / R \ evolution since 2001 '''''''''''''/____\''''''''''''''''''' Sustainable Biodiesel... ![]() | |||
Which begs the question, what sort of equipment is burning the glycerin as fuel? I have built several glycerin burners, and only the last of them was successful. I believe this stuff will not burn in any conventional burning equipment. Do you have customers for this goo or is this theoretical? My successful glycerin burner has 2-1/2 tons of masonry, including firebrick inner chamber and sand and circulating pipes to extract the heat. It is started with Yellow Heat burner, and only adds the glycerin as a secondary fuel. Its really hot and clean burning, but it takes a lot to get it started. My Yellow Heat burner cleanly combusts unfiltered and unheated vegetable oil, but it will not handle glycerin, AFAIK. See more about Yellow Heat at http://drop.io/wvuv5vc_YellowHeat. If you want to buy one, it is for sale at http://westernmass.craigslist.org/tls/979854222.html or from Homestead. Tom Leue | |||
Does that heater require an air compressor? | |||
Hello folks! I am new to the forum, and I would like to respond to the burning glycerin question. Our company has developed a fully automatic crude glycerin burner that works great! Please check our website, www.alterHeat.com, and click the MK Glycerin Burner tab. We are in the Cleveland area if anyone wants to see the burnar in operation! Bring your glycerin! Rick Krystowski AlterHeat.com rkryst@verizon.net | |||
Welcome to the board, what do they cost? | |||
Very interesting. Can you give an idea of cost and processing necessary to use raw glycerol byproduct as fuel? '05 CRD B100 '01 TDi B100 ![]() | |||
That's a lot of BTU. Anything smaller, for say, a 2 car garage? And how much methanol can be tolerated? '05 CRD B100 '01 TDi B100 ![]() | |||
And what is the consumption per hour? And has your glyc had the methanol distilled out, this is very important, if not the burn you are getting may be from the methanol in the glyc. | |||
From what we've read, glycerin contains approx. 70,000 to 80,000 BTU/gal. The smallest nozzle we can use is 2.0 gal/hour, so the lowest BTU is about 150,000. We have burned glycerin with the methanol removed, but it was hard to keep in a liquid state. We can reduce the viscosity by adding water or methanol. Again, we don't measure the alcohol content, we just make sure the glycerin is liquid at room temp. I understand that the glycerin from smaller producers may have a higher methanol content than larger commercial plants. We've had no problem burning either of these glycerins, regardless of the feedstock, as long as the viscosity guidelines are met. We can get a good idea of the alcohol content by viewing the combustion flame. Glycerin burns extremely slowly, methanol very quickly. Low meth glycerin gives a large, "fluffy" flame, higher methanol concentrations give a tighter, shorter flame. In fact we hope to market a version of the burner designed for high methanol content glycerin. We do not preheat the glycerin, and the higher meth concentrations ignite easier. We can eliminate the starting mixture pump assy, and ignite the glycerin directly. This will reduce the price by nearly half, and make the unit more affordable. We use a standard SunTec fuel oil pump on a Beckett burner chassis to pump the glucerin at 200 psi. The maximum volume of this pump is about 3.5 gal/hr, so with this small burner we are limiteed to about 300,000 BTU with glycerin, 350-400,000 with wvo and regular fuel oil, and 500,000 with waste oil. Rick | |||
I must just say Hmmmm I suppose I should read the law. But, I was under impression that this tax credit was intended for on-road vehicle fuel (or perhaps all purpose vehicle fuel). I suppose that one should expect a similar credit for home heating oil, boats, ships (in US Territory), tractors, trains, etc. What about liquid fuel being fed into a bio-reactor... to generate alcohols and gasses? | |||
Should probably read this thread, esp. the post by the EPA engineer: http://biodiesel.infopop.cc/ev...561019771#7561019771 1-tank Elsbett VW TDI , 220,000 WVO miles. http://ctbiodzl.freeshell.org/votdi.html and a '92 F-250 with only a FPHE | |||
I read the post by EPA engineer. I am unfamiliar with the air pollution aspects, but I am familiar with home brewed biodiesel and the byproduct glycerol. There would be virtually no sodium in the hydroxide or methylate form remaining in the glycerol. All sodium (or potassium if KOH was the catalyst) present in the glycerol would be present as soap or possible salt. The age of glycerol from time of production until time of incineration allows ample time for all remaining catalyst that MAY have been present in the glycerol to fully convert to soap (or salt). Therefore, it seams to me that "sodium in the air" risk is quite low. Most of the catalyst will end up in the bottom ash of any glycerol incinerator. | |||
Hello, I found the federal credit for using glycerine as a fuel, but does anyone have a list of incentives for burning glycerine at the state levels? Please any links, contacts, or state info. All help is appreciated. I've been searching high and low but have not been successful at finding any info on this. Thanks! | |||
Powered by Social Strata |
