Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Other uses for Glycerine by-product    glycerin buring..blast furnace..
I know I haven't read all posts in the this section so if there's link..please let me know Smile
what I would like to know and or build(maybe)..
is something to melt copper and other metals..but using a fuel source that ties into BD making..ie glycerin..or even biodiesel? or WVO? used motor oil.
in general those are waste stream for making biodiesel..
sure used motor oil is an indirect result..and only if you need to drive something to collect oil.
side track..
is it possible to use the above to make a furnace that can melt copper..iron..brass..
I would think AL, lead and other low melting point metals would be easy.
What I'm trying to do is use one hobby as a source of fuel for another?
I make biodiesel already..so could that be a source of fuel to melt metals for the other?
if you design ideas..please share..
things I have to play with..
burner units from oil fired boiler and furnace..pumps..
thinking about something like a rocket stove but using a fan to inject more air and pumping gylcerin in the burn to increase the heat..something like 2200F or so.
thoughts??
-dkenny
Dave :
Hope your doing well!!
I saw Murphy ( Murphy's Machines ) answer a couple of questions somewhere in here
that led me to believe he has a degree in Thermodynamics !!
His heater is probably capable of generating that kind of heat .
Good luck
Tom
Mercedes 300CDT
John Deere
On B99.?
Give this place a go: http://www.backyardmetalcasting.com/oilburners03.html
I'd say this guy has it figured out !!
Wink
Won't the Glycrin burn hotter than the oil ??
Mercedes 300CDT
John Deere
On B99.?
[url=http://backyardmetalcasting.com/guest_colin.html]http://backyardmetalcasting.com/guest_colin.
Location: Cork | Registered: December 05, 2010Reply With QuoteReport This Post
You could melt anything you want with this burner I made.
http://www.youtube.com/watch?v=KBE0T-8uUDM
I have used a much less powerful one in a brick oven and melted copper with little trouble.
THanks
I'll check into both setups.
-dkenny
wow the back year blast furnace is pretty cool..
I wonder how it would work using an oil fired furnance blower and fuel would work?
I might find out this winter..
-dkenny
