Page 1 ... 15 16 17 18
here's another, too bad can't do more than one. have several if it helps. maybe if I emailed them?
2003 Ford Excursion 7.3
2002 TDI New Beetle
Location: Rapid City, SD | Registered: 23 March 2008Reply With QuoteEdit or Delete MessageReport This Post
I REALLY like the venturi that Jamesrl made for me. It was reasonably priced and functions perfectly. It was very well constructed and probably the most attractive component on my system.
Do you have pics you would be willing to share? trying to figure out why our system doesn't work. thanks
2002 TDI New Beetle
got it to work! not the greatest suction, but enought to de-water the oil. Running the 1st batch tomorrow.
2002 TDI New Beetle
Originally posted by bj100:
Thanks to Graham's generosity in providing his knowledge freely, I have built a processor along the lines of 1-day ecoprocessor.
It's performing very nicely, but I was wondering if it's possible to vary the process slightly. I'm willing to do some experimentation if this hasn't been done, but decided to ask first in the off chance that it's been tried or someone has an answer.
What I am considering is whether it's possible to process the oil with methoxide, do the 5% prewash, and then distill the methanol and dry the biodiesel before allowing the glycerine to settle? By my way of thinking, if I've processed for long enough the reaction should be complete before this point, and therefore it won't matter when I remove the methanol and water.
The attraction is complete distillation in one process, less energy use and slightly faster processing.
There's far greater minds than mine at work on the subject of biodiesel production, so it's highly probable that there's a fundamental misunderstanding in my thinking that prevents my idea being feasbile - if so apologies for the simple question.
Any info appreciated.
Ben
Ben,
I have successfully demethed the total batch of bio AND glyc together in my GL style processor.
see my post here
http://biodiesel.infopop.cc/ev...449605551/m/97010537
Chug
1996 Transit Tipper
1991 Mercedes 709D
1994 Citroen ZX 1.9TD engine now in peugeot 306D
http://www.biofuel-uk.net/
Location: S.E. England | Registered: 05 September 2004Reply With QuoteEdit or Delete MessageReport This Post
Hi All
Help needed.
I have just re-built my old bio-processor to GL's design.
But I don't get enough suction on the venturi, it only pulls the meth mixture a couple of feet up the tube!
See pictures here:
Bio Processor Pictures
For close ups of venturi see nos 5 and 3, the rest of the pictures show the whole system. The plastic pipe cable tied to the venturi is the sight tube.
The venturi was 22mm pipe narrowed to 10mm, a 8mm hole drilled in the neck and 15mm pipe soldered over the hole.
I used my "old" method of injecting meth, picture 7, when the venturi failed.
The processor is a 200 lt. oil drum with a cone welded to the bottom and immersion heater fiited in the side.
Even with all the insulation and modified to 90 degrees thermostat I could only get system up to 80 centigrade. With this temp and poor venturi I only got a tea cup of water from my drying cycle - what sort of quanities do other people get?
The methanol reclaimation cycle only produced 1 litre - also probally due to the poor venturi.
So any ideas on improving venturi?
Is 80 degrees centigrade hot enough (with good venturi) to dry oil?
Any advice gratefully recieved.
Steve
Registered: 04 July 2005Reply With QuoteEdit or Delete MessageReport This Post
What is the recommended hose size for the vapor loop and the venturi suction line?
If the venturi suction hose is, say 5/16, then does the other hose in the vapor loop
have to be the same size?
Also, if the venturi is placed at the top of the processor, is there a need for the non return
valve in the suction line?
Registered: 24 June 2009Reply With QuoteEdit or Delete MessageReport This Post
Oceanflyer,
I don't know what the recommended size is but I had Jamesrl build my venturi with 3/4" inlet and outlet with a 1/2" male thread on the suction port. I already had some other plumbing stuff built for it. I use 1/2" ID braided nylon clear hose for my vacuum loop.
Hope that helps.
(There is no need to filter it (all the fine bits and pieces will end up in your glycerol layer). It must have no visible water in it.)
Graham,
Thank you for doing this. I am still using a apple seed variant but this looks interesting for future consideration. The above caught my eye so I thought I would comment. I used to not filter my oil and all the little bits ended up glued to the inside of my reaction vessel so I bought a 200 micron drum filter to filter that stuff out - much better now.
Dana Knight "dckfly"
Boulder, CO
Chevy Silverado Duramax
3 VW TDI (wife and friends)
Location: Boulder, CO | Registered: 13 May 2007Reply With QuoteEdit or Delete MessageReport This Post
Hello all ,I've just finished a GL One Day system and finally have a venturi that will lift the required height and volume.I've fitted a non return valve in the methoxide line but am not confident that the venturi will have the pull to suck through it .The valve is quite heavy !
Is this non return valve necessary ?
Location: NSW Australia | Registered: 09 April 2008Reply With QuoteEdit or Delete MessageReport This Post
I don't have a NRV on my GL style processor and most folks processors I've seen in the UK don't either.
Lots of folks (inc myself) have made the simple 15 min venturi with good results.
http://www.vegetableoildiesel....3368&page=1#pid27111
1996 Transit Tipper
1991 Mercedes 709D
Thank's Chug , it in the GL schematic but I'll gladly pull it out .
Done !
Chug , I can't get the 13mm to 8mm recuder here , so used a method suggested by nzunimogger on the venturi thread (a wooden plug turned to the taper then lead poured around it ).It's worked well .I can lift water about 1200mm with no problems but I'm still having troubles , it won't pull through the valve loop but it will pull if it is just a straight line down to a bucket .
I reckon perhaps my pump isn't strong enough ,it's one of those 40 litre /min jobs .It might do the job if someone has set this up perfectly but I don't think thats me .
I think I'll look around for a bigger pump !
I have to admit to getting a bit sick of stuffing around with this .....I'd like to produce some fuel !
Peter,
What temp is your wvo when you try to suck it in?
I also have a 35- 40 litre/per/min pump and it won't do anything with wvo until the temp reaches almost 40°C, at 50°C the wvo is much thinner and it really works well then, and at 60°C it's wicked!.
But I now have a jamesrl (ye olde copper basher) venturi fitted and it's sized for the pump and it will start sucking at about 30°C and at 60°C if your not careful it will suck ya shirt off!
1996 Transit Tipper
1991 Mercedes 709D
Chug ,
I haven't run any WVO through the rig yet , I'm still running water around and around trying to get the thing to operate as per expectations .It would be good to get this thing going as I have 1600 litres of WVO sitting in 44s and a good ongoing source .My car is a MB 240D.
I wouldn't mind posting a photo of things as they are or emailing it to you so you could tell me which way is up ! Except I have no idea how to post photos here ....I can post photos on other forums ,is this the same , just use something like Picturetrail to host ...then copy and paste the url here ?
One more thing and maybe another reason for a better pump .I've set up my heater in a box outside the main tank (an old compressor tank 100 l),up high near the venturi ,very similar to a photo on Graham's site .The main volume of oil will not be warmed until the flow pushs oil through this box .The idea was to keep the element covered at all times .
Peter,
yes you have to host on a picture hosting site and copy the url location here.
1996 Transit Tipper
1991 Mercedes 709D
  Powered by Eve Community Page 1 ... 15 16 17 18
