I find that it lowers your yield.
Alvin 2001 F250 Crewcab Lariat 4x4 Vegetarian 7.3 Powerstroke |
Yes Lawn,
As binuya says it can reduce your yield. When I water washed my fuel, I did it in a drum with cold water from a garden hose. I use KOH and static washed at least 2 times allowing it to sit overnight before draining. I used about 5 gallons of water each time. I introduced the water down the inside of the drum to avoid agitation. After the static washes I then sprayed the water on the fuel from the hose with the nozzle spraying a course mist over the fuel (about 5 gallons). After draining that I gave it a go get em with the hose for the next washes. The key to avoiding emulsions was the static washes. It really removes a fair bit of soap. |
lawn
-too much koh will make more soapand reduce yield. -about your wash, do you do the 5% pre wash? if not , this really helps. follow that with one or two static washes then bubble. even a very small amount of byproduct in the bio can cause huge problems. i have also been washing with cold water, and that can cause an emulsion faster than washing with hot water. I am told by a chemist that I correspond with, that the ion exchange is much increased with hot water (I don't know what that means, but I will find out) Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
Someone here once compared it to washing your greasy hands with cold water vs. hot water. The soap and grease break more readily with the hot water.
Remember that with KOH, soap stays in suspension a long time.(Especially with all that methanol in the bio). I also do 2-3 static washes, usually cold and settle a day before switching it out. This helps immensely, as Biotom and DoubleD pointed out. Sometimes, if I can't get to it right away, it will sit for a few days before I drain the last static wash. When I'm ready to proceed, I heat to 120f, mist a few, bubble a few. The instances I've had problem emulsions, I use salt. For 45 gallon batches with 8-9 gallons of water, I'll dump in about a pound of salt, heated bubble, and it's fine.(I'll do couple extra wash cycles than normal) Vinegar is not advised. Alvin 2001 F250 Crewcab Lariat 4x4 Vegetarian 7.3 Powerstroke |
for the washing thanks for the help, i'll try the static washing first.
KOH usage. i use the dkenny process but i reduce the acid % to .10. on 142 liter batch i use 5gal methanol on acid, 130-f mix till T stops dropping. mix 13L methanol and KOH (base 6+T), process till i can get back to it. take a sample and check 3/27, usually fails. reprocess 4L methanol and 142-284g koh, pass 3/27 and 5/27. sound about right for koh? KOH is 90%. any mods? jonathan |
total methanol is 23%, sorry about the gal and L.
5 gal = 19L |
what's too much?
this is a good question.. A long time ago...when I was learn the BD making..long prior to the 27/3 test.. I had batch that did work..or so I thought..no separation..also no thought on base/base processing..at the time..yea THAT LONG AGO!!! but... I was using KOH and KNEW from past mistakes that I COULD!!!make glop if I used too much. well.. this batch didn't work..darn.now what..not separation..darn(i think I used stronger lanuage here!!!)..but wait I know I how to make glop!!! a special talent no less so I started adding KOH to samples from my batch that didn't work... well um...at 40g per liter it still worked..Thins about that a second..40G per liter...if I was using a base of 7 that 33g per liter(titration, I know it wasn't this high but 10x) I'm not sure how much more I needed to make it work but it turned out my oil volume was wrong..before you think it was this far off the starting T was less than 3KOH..this was before my AE days..so 10X KOH will still work..unlike NaOH.. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
