Biodiesel & SVO Home
Biodiesel & SVO Forums
Making Biodiesel
Got another emulsion. This one is odd|
Just a note.The other enulsion 300+ batch had a perfect 27\3 test.
how much methanol did you use on the 320 gallon batch..around 64 gallons (20%) but only got 25 gallons for glycerin out??? you should have gotten around 64 gallons or more. this alone will make an emulsion when you start washing..
do you use the 5% prewash? -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
I agree on the glycerin part. Should have gotten more. Where are you in Myrtle Beach? Ilive in Georgetown.
fORESTBROOK AREA. DO YOU KNOW KENT ROGERSON SEA71?
WE FOUND THE GLYCERAN AND OUR WATER THEY WERE MIXING AND FORMING THE BOTTOM DARK LAYER I SAID WAS SO LARGE.
I took a test sample put in a jar let settle.Marked the top of both layers.Then added water to see which one went up.I figured if just the top then the bio was holding it.If both went up but the bottom raised the same as the amount of water added.Then the water was goiing straight into the glycerin and it looked like so much in the prosseser because we had addeed 40-50 galons. Thanks for the hits i had some ideas just wanted to hear someone else say it. |
that is also why prewashing works..it also pulls most of the soap from the biodiesel into the glycerin layer. water and glycerin like soap.
Making Biodiesel
