after some years of humming and arrring I have finally got round to processing 80litres of oil in a Graham Laming style processor. What I have ended up with is a cloudy diesel.
My production method was a follows.
80 litres of WVO
titration was .5g NAOH which I added to 3.5g per litre NAOH
16 litres of Methonol
Processed at about 45-50deg for one hour.
added 4 litres of water and run for 20 minutes
left for just over one hour. Drained off very runny glycerin in to 4 demijons till clearish liquid came out. (16 litres waste)
rest decaneted into large drum to settle ready for washing.
Having read various theads last night and today. My questions are:
Should I have made base 5gm NAOH?
Should I have run for longer than 1 hour?
Did I had too much water?
My Glycerin waste should it have been near 20 litres eg 16litres of meth and 4 litres of water.
I look forward to any answers
Luke
Registered: 22 November 2004Reply With QuoteEdit or Delete MessageReport This Post
Hello Luke
Yes if you want to pass the 3/27 test
Saint Tilly
what is the 3/27 test
Luke_UK
Have a read here
It is quite a long thread but the 3/27 test is easy and will tell you a lot about what you are doing wrong.
thanks will have a read a revised my process
have tried the 3/27 test and it says suggests i did not use enough NaoH but I knew that
Question
I put in 3.5g per litre instead of 5g base, if I put in 1.5g which is what I was short by, how much methonol should I use?
50 ml/L should is about normal for reprocessing.
Also, process longer next time and since you NOW know about the 3/27 test, pass it before you turn off your processor.
Jim...
'03 Dodge Ram 2500, 5.9L Turbo, 65K miles.
B50 - 250 miles (no problems)
B66 - 350 miles (no problems)
B90 - 2,500 miles (no problems)
B100 - 2,300 miles (sweet)
420 gallons brewed
Location: Lost Wages, NV | Registered: 22 January 2008Reply With QuoteEdit or Delete MessageReport This Post
Thanks will try the weekend
Jim...
He already added water to the batch. Reprocessing probably won't push the reaction any further. I never tried reprocessing biodiesel that already had the 5% water pre-wash but I can't imagine anything good coming of it. Wet biodiesel and NaOH sounds like a recipe for disaster.
Ken
Location: NW of Atlanta, GA | Registered: 17 May 2006Reply With QuoteEdit or Delete MessageReport This Post
