Biodiesel & SVO Home
Biodiesel & SVO Forums
Making Biodiesel
Methanol Pump - Any body used these, any feed back
Topic Closed|
I found these gasoline/racing fuel pumps on the web.
I am wondering if any one has any idea on how safe these to use with Methanol. And if they are good enough for methoxide mixing say 5-10 gallons of methoxide. Most of these are rated at around 120 GPH, which is 2 GPM. That should circulate about 10 gallon tank of methanol in about 5 minutes. I am hoping If I run this with an inline static mixer for say about 5-10 minutes. That should get me a good level of mixing for the methoxide. http://store.yahoo.com/gofast/elfuelpum.html http://www.cpperformance.com/detail.aspx?ID=3677 Does this make sense. I am looking for 2 uses. 1. to mix methoxide by circulation through an inline static mixer pipe. 2. to pump methanol into the methoxide mixing tank from a methanol storage tank. Thanks, Sarvi |
http://store.summitracing.com/default.asp?Ntt=fuel+pump...search.asp&x=45&y=16
you need a pump like this. it MUST be rated for alcohol. |
What I am trying to build is just a small prototype. Want everything automatated eventually. So hand mixing is not an option.
Sarvi |
member 2008 Sponsor |
You'd have to look into it a bit more, although they claim their pumps are "chemical resistant" and many are equiped with Viton valves and parts. I have one of these but do not use it for methanol. An email to them about this specific chemical application should yield the desired result.
http://www.shurflo.com/pages/new_industrial/Industrial/...eries_diaphragm.html ** 7 engines on B100**My reactor/processor :B100WH.com **The Colaborative Biodiesel Tutorial ** Veggie Energy 4 Diesels -a Newcomer's Hardware Guide ** Biodiesel Glycerine Soap - Make & sell soap from Biodiesel Glycerine **The Ultimate Winter B100 System |
While the fuel pumps are rated fro methanol, they are NOT rated for KOH of NaOH. They will fail rapidly if used for pumping methoxide. "Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO "Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends. "Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks. '79 300D poor body (donor & parts) "Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004). "Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO. |
I've used an air powered beverage pump for over a year without problem
I burn methanol in my race car so I have some experience in regards to the pumps.
In my experience, even the pumps rated for methanol will fail prematurely if you leave the methanol set in them. You can use a cheapy $30 electric fuel pump from Autozone if you are willing to flush it out when you are done and leaving the system set overnight or longer. I don't see any reason why you couldn't use it (cheapy Autozone pump) for pumping methoxide if again you are willing to flush it out. I now use a belt driven pump for my race car because of my new induction system but for either all you need to do is squirt a little wd40 into the pump and it will clean and lubricate the pump and seals. Maybe someone else can pipe in about weather or not there are any comtamination issues with using wd-40. You don't need very much. About an ounce or less will do. I hope that helps... Wayne Very funny Scottie, now beam down my clothes. |
Hi Ant,
II din't realize how an air-operated pump works. Can you tell me what size compressor i would need approx. for mxing 3-5 gallons of methoxide and cirulate/agitate/mix around 20 gallons of oil/methoxide. Would a compressor like the ones below http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_...fdfgidgkg.0&MID=9876 http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_...fdfgidgkg.0&MID=9876 be powerfull enough to pump liquids and possibly create pressure/vaccum using a venturi pumps. I couldn't find the air operated pump you mentioned for $10 ebay. any pointers/links. Thx, Sarvi |
your links lead to some big gennies.
The pumps dont take a lot of air. Almost any compressor will work. I have even used a 12v tyre inflater pump to pump bio (slowly) with them in a pinch. four for $25 These arent the best (biggest) ones but will give you an idea of what I'm on about. mathematical elegance -- desired result achieved with minimal complication |
Dear Ant,
Could you give me an approximate flow rate in liters/min for the beverage pump(s)? Finest regards, troy |
well it depends which one you get and how much air you feed it but pumping methoxide you can get about 25L a minute out of mine running on a small workshop air compressor.
Topic Closed
Making Biodiesel
