Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    Storage of biodiesel
JohnTF,
March 20, 2008, the Nathional Biodiesel Board released the following study report confirming Biodiesel is safe for underground steel tanks. This is not exactly what was being discussed here, but the study does seem to point to the fact the we can store our biodiesel in mild steel tanks with less reaction than with regular ULSD. The conclusion is set forth on the first page and is only 2 pages long.
http://www.biodiesel.org/resources/pressreleases/gen/20080320_tankcompat.pdf
Ken
Ken
1989 Ford F250 7.3 200,000 miles and 75,000 on biodiesel
Location: Northern California | Registered: 17 July 2008Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by hoofguy:
if you have access to CO2 would you be able to cap off the top with that if you couldn't fill a larger tank quickly enough?
sorry for hijacking, just curious. this is what we are thinking about doing.
I'm not sure why, but nitrogen blanketing is pretty common. I would bet CO2 would work, but I dont' know if there are any ramifications of using it.
Registered: 14 August 2006Reply With QuoteEdit or Delete MessageReport This Post
Alken , I wish I had a connection to some of the readings on bio in steel tanks , since now we are looking for detailed info .
It is possible that some of those statements about bio reacting with carbon steel had there issues also .
But again reading this document , is all it is relating to , is the steel reacting / rusting / corrosion to bio , not the bio reacting to the carbon steel .
94 dodge ram 4x4 , Cummins 5.9
need to get an other vw diesel
the others rusted away long before the engine
Would excaust from a tail pipe from a running car scavenge O2 , it would be alot cheaper than CO2 if it would work. just a thought
Location: Texas | Registered: 28 May 2007Reply With QuoteEdit or Delete MessageReport This Post
