Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    Go/NoGo changes at 25 seconds? OK for BioPro 190?
My Go/No Go test does not change color at all until 25 seconds have past and then it instantly turns yellow. Does this mean this oil is not suitable for the BioPro 190? I have not done an actual titration as the manual recommends using the go/no go.
Registered: 11 June 2008Reply With QuoteEdit or Delete MessageReport This Post
Hello sheepfarmer
Perhaps it means the oil is good if you react it within 25 seconds.
Saint Tilly
Not having a lot of experience with the go nogo test they provide, I will guess what your result means.
The oil you are testing is on the cusp of go/no go. After 25 seconds, enough CO2 has reacted with the catalyst that it changes and neutralizes the base to create the yellow color.
Andrew
http://biodieselcommunity.org
03 Dodge 2500 B100 homebrew
79 Rabbit B100 homebrew
Are you shaking it?
If not, you need to shake it after you put the oil in.
If it changes to yellow after 25 seconds, then yes, that's a fail.
It means it fairly close to the upper limit, but if it goes yellow after 25 sec, yes, it's a fail.
Also, to explain how this works to the rest of the folks....
It's just a reverse titration.
Think of it like adding enough titration solution to a cup to be equivalent to 5% free fatty acid (roughly 9 mL of titration solution if using a KOH titration solution of 1 gram KOH to 1 liter of water).
The indicator in it is Phenolphthalein.
-Graydon
-Graydon
Utah Biodiesel Supply - Biodiesel Parts, Books, Supplies, Decals & More
The Rabid Biodiesel Nut - A Blog On All Things Biodiesel
