Sponsors    Home    Forums  Hop To Forum Categories  Making Biodiesel    World Famous Dr Pepper Technique (Pat Pend)
Page 1 ... 8 9 10 11 12 13 14 ... 26
5-star Rating (5 Votes) Rate It!  Login/Join
i have a question is clear liquid shorten same as veg oil or is it made from veg oil and can it be used for biofuel?
Registered: 23 December 2005Reply With QuoteEdit or Delete MessageReport This Post
yes, and yes. It's partially hydrogenated vegetable oil so it'll have a 'worse' cold weather gelling point than non-hydrogenated oils generally, but it should work well otherwise.
Mark
i started making a 20 liter batch and like a dummy didnt let it cool and added half a my meth
and lye mix it boiled off have i runed this batch a oil can it still be made into fuel if so hw and i read a peace on washing mike pelly says to add a little vingar ot it before wash if so does anyone knw how much vingar to put in for liter
Hello cheepride
I suggest you start over with the oil as if you have done nothing to it.
But do it with a test litre first.
NO VINEGAR or any other acid in the wash.
Mike Pelly apparently is still 4 years behind the times.
i made four liters and tryed it in an old furnce i have in out house and it seemed to stop up the burner what can i do to stop that
i was trying it in the furnace befor tying it in a auto glad i didnt put it in lol
well as always i sent the first to the wrong place so
here i go again i made my first batch a 16 leters dont the titration test mixed as the lye and myth
this is what i got about 8 leters a fuel and maybe the same in waste product
the question is to create that much waste have i used to much lye or too little
can the waste be run again its almost like a soild from like maybe a bar a soap that has gotten two worm
i have read all i can find and wondering if this has happened to someone else and what i may have done wrong
many many thanks for the help all yal have
given already
still at the drawing board
Hello cheapride
What was the titration?
How much NaOH did you use?
How much methanol did you use?
What temperature did you do the reaction at?
i use five as a base then i did the titration the titration was four which i added to five per litter
2 i used 144 g naOh
3 i used 4 litters myth mixed to naOh
4 the temp im not really sure but i think
about 50c may less
i did the titration three times and it came out the same all three times
Hello cheapride
The chemical amounts sound right.
How long did it take for the gel to occure?
Does all the gel look the same, or are there different qualities of gel?
Did you make sure there was no water in the reaction.
i left it over night went back to it the next morning and it was there and yes it was all the same no different qualities a gel
and im sure there wasnt water in the mix
i have made small batchs out a the same oil and it did well and made one ten litter batch and it also did well atleast i think it did comparing it too what i have experenced so far
well to say the least i have enjoyed what i have learned and experenced up to this point
thanks a bunch to all yal
for all the help
cheapride
Hello cheapride
Describe the gel? Colour in particular.
How cold did the Biodiesel get overnight?
If it looks white the biodiesel is frozen.
The next thing that comes to mind is soap binding the esters together.
This most frequently occures when using high tallow WVO, and High FFA WVO,
To check for this, take about 300ml of the gel from the top and put it into a 2 litre dr Pepper bottle and pour about 300ml of warm/hot water on top.
Screw top down tight.
Shake hard for about 10 seconds and see if anything happens.
hi tilly
the gel looks kinda dark golden honey in color and sorta holds together and it got about down to about thirty five degress f and im almost sure it has some tallow in it too
now another thing how do i tell when the reaction is complete
and yet another thing i was washing well trying to wash 38 llitters a oil i made i added the water and stired it and it turned into something for no better way to tell you what it looks like i would have to say it looks like chicken soup how can i make this stuff brake back down its been twenty four hours sents ive done it
i have read that really hot water will start the reaction or use salt or vingar
well i though i was doing so well but i guess i am in a sents making all these mistakes in the beginning when i figure out all ive done wrong ill have it down pat lol
which would you think would be the best of the three salt hot water or vingar to start breaking down my soup
thanks bunchs for your help
cheapride
Hello cheapride
A honey colour suggests a soap gel.
Have you tried to wash a sample of the gel as suggested above?
The safest way to wash is to "Mist" water over top of the biodiesel.
I never had emulsions so am not an authority on how to handle them.
Put a sample of you chicken soup in a pan and heat it on the stove.
Be carefu of water bubbling up as it heats up. With any luck you will see something happen by 100deg C.
Another idea is to mix equal amounts of the waste glycerine into the chickensoup. This will usually break the emulsion.
HI Tilly
I took a sample and heated it by puting hot water in it . It gave me three layers
one water second something like rendered lard
the third dark orgne liquid i think is fuel
by morning the second was almost gone now
1 should i reheat the remaining batch and pull the fuel off and discard the rest
2 how can i keep it from being this way in makiing it in the reaction
i hope that i and others that are new can learn from the mistakes i have made
im really grateful for this board and everyone that has given help to us all anyone that has input feel more than welcome as i need it
if i have a big percentage a tallow will i see this a lot
is there a way in the reaction process to prevent this
again many thanks to all
Cheapride
Hello cheapride
You say you put hot water in some glop and now you have orange juice on top of water.
If this is correct then yes, the orange juice is biodiesel and the bottom is water.
This means the problem was a gel formed by soap.
Just go ahead and wash the rest of the glop and it should seperate into biodiesel and water.
HI Tilly
Well success at last the heat thing worked
I am going to wash the remaining fuel and see what happens
I was wondering with using wvo should the fuel be clear or have a redish brown or something color to it
and a gain thanks you saved the day here
Cheapride
Hello cheapride
The fuel should be crystal clear but will have a colour to it which will be determined by the oil being used.
I am glad to hear the problem seems to be solved.
hi tilly
I made a five gal batch a fuel washed it three times and dryed it it wouldnt clear up so i done a titration on what i made it took one ml a lye solu to change color and hold i then used a 3.5 as a base and added one grm lye to a liter a already made fuel it came out clear really clear what am i doing wrong that the big batch want come out clear
Hello cheapride
You should be using 5g for the Base amount not 3.5g
  Powered by Eve Community Page 1 ... 8 9 10 11 12 13 14 ... 26
