Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    Please check my arithmetic
Closed Topic Closed
I'm about to prepare my very first batch by the Tilly method, but the super accurate scale which I have available to weigh out the lye is the one I use for reloading ammunition for hunting and target shooting, and it is calibrated in the ancient scale of "grains" used for centuries in the sports related to firearms. There are 7000 grains in a pound (437.5 grains in an ounce), so am I correct in multiplying 7000 times 2.2 and then dividing by 1000 to conclude that there are 15.4 grains per gram?
I have plenty of used peanut oil available from a local seafood place where our department (Classical Languages) holds a luncheon meeting every 2 weeks or so, and many other restaurants in southeastern Virginia are just crying for a more reliable waste oil collection company.
Life is like a beaver colony: one dam problem after another.
Location: WMSBG, VA, USA | Registered: 22 April 2002Edit or Delete MessageReport This Post
There are indeed 15.4324 grains per gram.
Cheers, Joe Smile
Location: Sterling Hts. Michigan USA | Registered: 18 October 2001Edit or Delete MessageReport This Post
<Guest>
...are what I started off with too
One minor detail though...be careful of the effect of lye on the surface of the measuring pan...mine was a nicely anodised gold. Now its got etched spots through to the metal...Pity.
Cheers, James From Perth
- with the Holy Ammo Scales... Eek
To avoid damage to my "good" scale, place a dish in it that the lye will be measured into. You just have to weigh the dish first, then subtract it's weight from your final measurement.
Digital scales (some or all, I can only speak for the few I've seen) have a "tare" feature that allows you to compensate for the weight of a container.
[This message was edited by Saturn on 05 September 2002 at 11:47 AM.]
Location: Rochester, NY USA | Registered: 02 August 2002Edit or Delete MessageReport This Post
I bought a digital mail/letter scale that weighs in grams and ounces. I think it came from Office max. You might want to check any office supply for cheap/inexpensive scales. Big Grin
[This message was edited by dyoungen on 04 September 2002 at 05:59 AM.]
Location: Hawkinsville, Ga. 31036 | Registered: 24 October 2001Edit or Delete MessageReport This Post
Closed Topic Closed
