not washing means glop in your tank and the eventual clogging of your filter(s)
Shawn
2006 F-250 6.0l PSD Crew W/ FS BED Runnin' on Homemade B-100
"Allow myself to introduce...myself"
| Location: sunny Palm Bch.County, Fl | Registered: 16 July 2006 |    |
quote: Originally posted by Obie: I am just curious how many people out there are using their bio unwashed. I know there are going to be plenty of people saying all the bad things that can happen, but I know a few people locally that are not washing at all, they are doing fine. They also do not titrate and just use a base of 6.25 sodium Hydroxide. I tried not washing and felt the car was harder to start and had less power.
I'm sorry, but if you shortcut your titration and use only 6.25 grams of lye, you are asking for seriously mal-converted fuel. In fact, with some oil you won't even get a separation. If you don't want to run washed fuel, you definitely need to make sure you get out the methanol - that may cause the starting issues. I tried it once in my Mercedes, I still had methanol in it, and the idle quality was terrible.
'05 CRD '83 240D
Hi OBIE, 6.25g NaOH/liter? Must be some pretty good oil if it actually converts. My oil titrates around 14-20 KOH and requires an acid/ base conversion to split and pass the 3/27 test. Adding 10g KOH/liter only gives me oil, methanol, and lye. That's certainly not good for an injection system. Take your time, titrate, and make small batches to start out. It could be an eye opener (especially with crummy oil). Don't let this discourage you. Just my $.02
feed a farmer - starve a terrorist
| Location: central virginia | Registered: 13 March 2008 |    |
As I recall6.25g NaOH was what mike Pelly's formula on JTF recommends
Saint Tilly
| Location: ลึก ประเทศอินเดีย | Registered: 03 March 2001 |    |
quote: Originally posted by trtmntdude: not washing means glop in your tank and the eventual clogging of your filter(s)
I've made and run unwashed bio through 2 Mercedes, Ford F250, Back hoe ,tractor and rough terrain crane, over 1300 gals. and never plugged a filter or had any trouble. I use the 5% glycerin prewash method, dry completely , then run through a 10 micron , then a 5 micron filter. You will have more problems with water in the bio or using unfiltered bio. you can see in the attached picture the difference in soap from no prewash as compared to the prewash method. I'll need to reduce the size of my pics, but the bottom line is that the prewash method leaves up 75% less soap in the finished bio. I've never had a problem. Just my 2 cents. wnybiodieselcoop@verizon.net
| Location: Western New York | Registered: 16 April 2006 |    |
quote: Originally posted by wnybiocoop: ...the bottom line is that the prewash method leaves up 75% less soap in the finished bio.
What is the ppm soap level in your finished biodiesel? Ken
| Location: NW of Atlanta, GA | Registered: 17 May 2006 |    |
