Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    % of Methanol in the NW?
I was told by my Methanol supplier that each area of the country requires different %'s of Methanol for processing BD. I'm using 100% lye and located NW of Olympia, WA. and since this is my first attempt at making BD, I don't want to waste materials. My supplier suggested 8% which sounds low. Any help appreciated. Jim at jpaulstra@hotmail.com
Registered: 03 December 2007Reply With QuoteEdit or Delete MessageReport This Post
This sounds like your supplier thinks that by diluting the vegtable oil you're actually making BioDiesel.
Colder climates you need to dilute it more.
Check the forums here for proper recipe and procedures.
Try small batches first. It won't be a waste because you will be learning.
If you don't make a solid chunk you can add it to your tank after washing & drying and gain the lubrication benefits.
Goodluck
Location: The Land Between Two Rivers | Registered: 14 May 2005Reply With QuoteEdit or Delete MessageReport This Post
Hello Jim
Who is your methanol supplier?
The world and the internet is full of inaccurate biodiesel information.
Your methanol supplier is adding to it.
I sugest that you should do your first few batches using the World Famous Dr Pepper Technique (Pat Pend)
Saint Tilly
Would you be around shelton maybe buy your methanol at small and sons. I talked to them a long time ago and what he is referring to is svo dilution sounded like to me not biodiesel. The last methanol I bought was from there cheaper than tarr inc at that time and much closer to home.
Location: wa | Registered: 09 May 2005Reply With QuoteEdit or Delete MessageReport This Post
Rodman68, Yes I did purchase my Methanol from Small & Sons. You are probably right. I may have have misunderstood Don. Thanks
He is still wrong!
Methanol is, virtually, insoluble in UVO. Adding methanol will not dilute the oil. The added methanol will just float to the surface.
Impurities in the UVO may alter the relationship, but in pure solutions methanol is not soluble in oil.
