All the information you need is on here-start small with 1 Lt test batches(use new oil to start)-learn the process-make sure you understand the health and safety issues-then you can scale up to bigger batches-post any problems,people will help
Heating with OPEN FLAME when mixing methanol and oil is dangerous. There are barrel heaters that wrap around the outside or you can weld a fitting in the barrel and fit an element from a water heater in it. The latter option is dangerous too if the element is exposed to the surface of the oil. |
have a look at our collaborative biodiesel tutorial (CBT) lots of info for beginners and advanced brewers.
http://www.biodieseltutorial.com/ ************************* 1996 Transit Tipper 1991 Mercedes 709D 1994 Citroen ZX 1.9TD engine now in peugeot 306D ************************* http://www.biofuel-uk.net/ The Collaborative Biodiesel Tutorial http://www.biodieselcommunity.org |
I was and still am pretty new... but my best advice is to read read read... it's ALL on here somewhere.. yet I asked a dozen or so quesetions as I got up and running. Remember that people who post here are passionate- so they'll be quick to offer an opinion. It's often helpful, though sometimes can have too much passion in it. Everyone does it differently. There is no exact science to each step- everyone has a little twist to their processs which works for them and not for others. Best thing you can do is read as much as you can. start small. test along the way. ask specific questions as they arise. Be prepared to spend more time and money than you think - at first. I planned a week to build my reactors... took me 3 till I got it set up in the way that works "for me" and I'm STILL fine tuining.
Now your questions... Propane flame is not the safest unless precautions are taken. I have a propane fired heater for one step though. But it's never on in the presence of "open" fuel.. only when it's in the reactors and is not going to allow vapors... especially with methanol. And i have a fire extinguisher in the garage ready to go in case I need it. The lined drums are bad because that lining will cook off and that's probably not good for the fuel. However, storing a batch of clean bio in ther would probably work well unless the bio eats the lining.. it destroys some plastics... I'm using about a liter of lye and 22 liters of methanol per 100 liters of oil... you can plan for a similar amount once you do larger batches. Racing fuel is usually pure methanol... check the label. A completed process will pass the 3/27 test... look it up. in fact there's a good half dozen tests to check various things in the process... ALL are VERY helpful. A pump will likely be too forceful for initial washing.. you're better off spraying on top with a mist and saving the aggressive agitation until most of the lye is washed out. I don't even bubble until after the second wash stage. And a garden hose from hosuehold water is OK. Don't forget the environmental steps too.. neutralizing wash water with vinegar or other mild acid and recovering methanol and neutralizing lye in the glycerine. Otherwise you're doing more harm than good. And yes there's a few test's for dryness... though until it's clear, there's no way it will pass any of them. Hot pan test/crackle test is good for checking for water in waste oil and clean bio.. there's more scientific approaches too.. Once it's dry it's good to go... though after sitting a week or two there still might be a little settlement. but you can use it right after it's dried. Hope that helps.. keep reading... and designing... and reading... and posting questions.. and reading... and building... and reading... |
All very good information. Thanks everyone.
I'm going to think of another way to heat the oil if possible. Cost is an issue for me unfortunately and i was hoping to not have to use electricity to heat with due to the cost of the heater, and the cost of the electricity itself. A heater capable of heating 50+ gallons and providing more than a 100 degree rise will be quite expensive, not to mention the electricity it will consume. Perhaps it wont be as bad as I expect tho. With the propane I figured it would be cheaper, at least initially plus I could keep track of my total cost of production easier that way. I don't know of a cheap way to keep track of electricity consumption and cost. But with an open flame being so dangerous and my drum with the coating of some sort in it, that idea probably isn't as good of an idea as I initially thought. When we speak of mist washing, are we referring to misting (spraying) the biodiesel over a tank of water? Bubbling i would assume is using an aquarium air pump to pump air through a tube to the bottom of the biodiesel tank, correct? Thanks again everyone |
Hi touque and welcome to both the site and the world of BD.
To make beutiful relatively trouble free Bio the recepe is ... 20% meth 7 + titration of lye ..(Koh) In my case STIR at 50 degrees C for one hour After this you settle, draw off glyc, filter/wash, dry (if washing), use The secret to sucess is ...Tritate, Tritate, Tritate ... be careful with measurements. Should you encounter any problems, folks here will help just ask specific questions giving as much info about your process should you have any problems. As you FINE tune your plant and process small deveations from the recepe can be done ...i.e down to 18 and up to 22 percent meth ect the biggest mistake made by most is not getting the lye amount right .. to much makes soap .. to little gives incomplete processing. As for your plant ..a personal choice .. drum and mix (my choice) or a version of appleseed, either way there is plenty of info here ..read up , ask questions and good luck, BE SAFE ALWAYS!. Let us know how you go as you go forward. Regards Kev |
