Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    OIL Extraction How To
Hi!
Does anyone have or knows a PRocedure how to EXTRACT Oil? from coconut, Algae or whatever...
I want to learn how to extract oil and i cant find any good resource on the web.
Thanks in advance!
Registered: 30 July 2006Reply With QuoteEdit or Delete MessageReport This Post
This thread has some information on it:
A new method of extraction
Location: Gaithersburg, MD, USA | Registered: 21 July 2003Reply With QuoteEdit or Delete MessageReport This Post
There are two methods:
1. mechanical press
a. hot press
b. cold press
2. chemical solvent extraction
Method 2 removes more oil, but leaves the seed hulls as mostly worthless for anything other than fertilizer.
Method 1 leaves a few percent of the oil behind in the seed hulls, which all together remain as a pressed seed cake. Pressed seed cake from sunflower, safflower, canola (mustard, rapeseed & soy are valuable as an animal feed. A hot press may remove so much oil and use enough heat that again the seed cake is worthless for anything but fertilizer.
Coming from an agricultural background, I prefer the cold press method.
Google for 'oilseed expeller' and you'll find all kinds of things. This is one area where there is actually some good information at journeytoforever:
http://journeytoforever.org/biofuel_supply.html#Oilpress
Location: Colorado | Registered: 07 June 2006Reply With QuoteEdit or Delete MessageReport This Post
Hi,
As i mentioned i am familiar with those methods in terms of theoritical background of the said methods.
However, what i am looking for now is Procedure Or a How To Extract the Oil same as the HOW TO Make BioD instructions step by step and requirements...
cheers
