Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Making Biodiesel    High Schooler needs help starting out making biodiesel. Has a kit from duda energy
Any help appreciated ASAP! My son excitedly started his science fair bio diesel making with some used fryer oil and a kit from Duda Diesel. He mixed the potash flakes in the isopropyl alcohol for longer than it should have taken and they still did not dissolve. In the kit he just bought the batteries were corroded in the tester so we are wondering if the kit is old and the flakes or alcohol are not effective anymore?? When he mixed everything up the flakes are on the bottom of the oil-you see them white and there is not separation occurring that we see. It has been 24 hours and he is getting antsy as he is on break and wants to get testing the biodiesel!
Registered: December 24, 2014Reply With QuoteReport This Post
Potassium hydroxide doesn't dissolve very well in isopropyl alcohol. How much potassium hydroxide did he put into how much isopropyl alcohol? Is there any water in the isopropyl alcohol?
Perhaps he has mistaken methanol for IPA. Methanol and KOH are the usual reagents added to waste vege oil to make BD. IPA is used for titration.
thanks for your reply..as soon as I can get ahold of him I will have him reply..he was doing the titration but for the actual separation he should use the methanol? As you can see I don't know much about this as he is doing it on his own! I will have him respond tomorrow. Do you have a recommended process? He has the titration kit but what else goes into the veg oil besides the methanol and how much? And where do you get methanol? Can you use HEET?
Yes, you can use HEET, I think it is a trade name for methanol in USA.
The process will not work if you use potash in ipa, it has to be dissolved in methanol. Here is a link to one of the simplest ways to make biodiesel for newcomers. http://www.make-biodiesel.org/...dr-pepper-style.html
Hope you manage OK, if you get stuck, just post on here, happy christmas.
Others can advise you on HEET, we don't have it here.
Be warned that methanol and Na or K hydroxide mixed together is regarded as extremely toxic - no skin contact, no breathe fumes, no splash eyes. Wash wash wash with water.
Recommended process? How long is a piece of string. Maybe best you start with Tilly's Dr Pepper procedure. Fun and simple.
http://biodiesel.infopop.cc/ev...5551/m/857600061/p/1
Be careful to check out the red or yellow HEET, I think they are different.
Heet in the yellow bottle is methanol, (which I buy to do my 3/27's), and the red bottle Heet is isopropyl alcohol. Some time in the last couple years though, they put some sort of additive in their isopropyl which gives it a reddish tint. It made me a bit wary of using it for titrations, so I just buy 90% isopropyl alcohol at the drug store.
Alvin
'01 F250 7.3 4x4 Lariat Crew
'95 Mercedes Benz E300 D
I can recommend a process for your high school student. Dissolve 3.5 grams of potassium hydroxide in 100 millilitres of methanol. Warm 500 millilitres of new vegetable oil to 60 degrees centigrade. Mix the methanol solution with the warm vegetable oil for 30 to 60 minutes. If the mixing is done thoroughly while the liquids are at about 60 degrees centigrade, a separation should occur. So he will get some crude biodiesel. If you succeed in it let us know.
This message has been edited. Last edited by: WesleyB,
All of the information you son needs can be found at this website:
www.Make-Biodiesel.org
Don't let your child play with these chemicals unsupervised!!! Kids really don't understand dangerous consequences.
Calm down Biotom! Kid is in High School. Time for him to learn.
GotDzel
Waynesboro, Virginia
gotdzel@gmail.com
Location: Waynesboro, VA | Registered: December 31, 2005Reply With QuoteReport This Post
As little as 10 millilitres of methanol can cause blindness. Breathing it may be as bad as drinking it. Methanol is poison. Injesting methanol should be avoided. The caustic eats holes in the skin.
Thanks everyone for the links and advice. We will definitely take precautions and do outdoors. This is why I am jumping in here to find out some advice from those that know best! Some of the directions he has seen say to blend it in a glass blender. If he is only doing this a few times do you think it is okay to use a plastic one? Having a hard time finding a glass one for this. Thanks
I would be more concerned with the sparks generated by the blender motor. Maybe you could look into this method for small batches. It's how I learned the process when I first got started: http://www.kitchen-biodiesel.com/
Alvin
can he use the HEET and KOH? (instead of NAOH?) He is using waste veg oil and will do a titration before that.
DO NOT use a blender. Go to the biodiesel link I gave you above: http://www.make-biodiesel.org/ and read how to safely make biodiesel. You are endangering yourself and your kid with your limited understanding of biodiesel.
Science fairs are about education, do that first.
Hi jodiprchal,
Yes.
All the information you need is on this websitee.
For the easiest method of making boidoeisel you can not beat the World Famous Dr Pepper Technique (pat pend)
For the easiest method of titrating, you can not beat the World Famous Chopstick Titration Technique (pat pend)
thanks all..he has read over all of this with me and is going to try the dr pepper method. He will first do his titration and determine the amounts needed. He will heat the oil in one glass container. He has a chemistry type bottle to mix the methanol and KOH. It is a fairly large bottle and it might be easier and safer to use than the plastic pop bottle..? Does it matter if he adds the warm oil to the bottle with the methanol/KOH mixture or should it be the other way around where you add it on top of the oil? We are trying to research this every which way before he starts. Is it okay to use the glass bottle for shaking or why is the pop bottle recommended? Thanks
