ski
-before adding any more chemicals, do 3/27 and see if iy passes. could be that the remaining byproduct is being held in suspension, this is often the case after a repo, but since you are using 24% methanol, I suspect the methanol is holding the byproduct in suspension. If you need to force the seperation you can add back some byproduct from a previous batch, this will mop up the suspended byproduct. Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
Yup- after about 5 mins I'm getting a few droplets settling out in the 3/27...
Soooooo... more methanol and lye correct?? quantity? |
One likely issue is not enough catalyst in this "stage 2" part of your reaction. Also, in the post, you don't state any duration of mixing. Did this stage get mixed for at least an hour? If not, then you have lack of mixing as well. HTH. |
Seeing it did not pass the 3/27 test, I suggest that you try only 1g/Litre of NaOH rather than 3g. This was one of my early mistakes (reprocessing with 3g/L) and it gelled almost immediately and created a lot of soap. If it fails again, you can reprocess agian, in small steps. For future big batchs you might try 2 stages |
