Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Making Biodiesel    The oil absorbs water from the Air?
Hello, the oil I dry it in a fryer. And then I put it in a metal bucket to cool it. If I leave the oil for a day or several days, can the oil absorb water from the atmosphere?Thank
Registered: July 14, 2018Reply With QuoteReport This Post
2013 Sponsor
If the air is humid, it can absorb water from the air.
Did you filter the oil before heating it?
Rick
Hello RickDaTech, the oil filter it before heating it
2013 Sponsor
Psicro,
Oil that has been filtered, then heated up then allowed to cool slowly causes the water to drop to the bottom of the container. Covering your bucket with something that will slow down cooling and prevent convection currents will help the water to settle out.
It's the basis of the drying method used in this article:
http://www.make-biodiesel.org/...and-settle-tank.html
It is one of many methods used to dry oil. There are other methods that may work better, but you already have a fryer that can be used to heat oil.
Rick
