so far i guess i have one question : what about evaporation of the ethanol out of the fuel over time. presumably you would not want it sitting in vented tanks for a long time? equipment wise what kind of filter?
I have read you should mix the Master Formula for 10 minutes. How long is it heated at 55C(131 degrees F)??? Thanks..Don
| Location: Las Cruces, NM | Registered: 15 April 2006 |   |
quote: Originally posted by gatorguy: I have read you should mix the Master Formula for 10 minutes. How long is it heated at 55C(131 degrees F)??? Thanks..Don
I used to heat the oil to about 60 degrees C, pour it into a carboy, and then just mix in the ethox. Give the carboy a good shake, let it rest a couple of minutes and then another good shake. Done. Paul
| Location: Malmo, Sweden | Registered: 18 June 2005 |   |
