Sponsors    Home    Forums  Hop To Forum Categories  Making Biodiesel    WHW method with methanol present in wvo
Being that the HPT test will not work with glycerin pre treated wvo, does the methanol skew the results in the weigh-heat-weigh method?
Alvin
2001 F250 Crewcab Lariat 4x4
Vegetarian 7.3 Powerstroke
Location: Seattle | Registered: 06 January 2009Reply With QuoteEdit or Delete MessageReport This Post
Yes.
If the weight goes down after heating, you never know if it was the methanol that was driven off, or the water, or both.
troy
If you want to quantify the water content, you could do it in two steps. Weight a sample, heat it to below 100 C but over 65 C to boil off the methanol, then re-weigh the sample, then heat to over 100 C to boil the water off, and re-weigh.
I personally heat the WVO to about 120 C after I have done the glycerol pre-rinse and drained the glycerol. I hold it at this temperature until there are no bubbles rising from the heating element. I then do my reaction as the temperature drops to 55 C.
Location: Winnipeg, MB | Registered: 31 July 2008Reply With QuoteEdit or Delete MessageReport This Post
Some water will be lost in step one.
Andrew
http://biodieselcommunity.org
03 Dodge 2500 B100 homebrew
79 Rabbit B100 homebrew
Quite a lot actually. Making the test pointless in two steps. The WHW test will only test for moisture and volatiles combined, it can't really separate them.
