Biodiesel & SVO Home
Biodiesel & SVO Forums
Making Biodiesel
Can I make bio from this crap?|
You could pump it back into the bottom of the tote and go back to sucking good oil off the top. If you put the discharge hose all the way down to the bottom of the tote and pump slowly it shouldn't disturb the upper layer too much.
Ken |
member 2008 Sponsor |
DO just what you say, de-water it with heat and circulating, then follow it with a titration to see how it comes out. May not be as bad as it looks, if it is, mix with the top layer stuff to get an "okay" oil.
----------------------------------------------------------------------------- 40 Gallon 2 tank Biodiesel processors, Well built, Easy to use, Quality parts. pm for pictures and details! http://www.revolution-biodiesel.com/ Running B100 in my Ford 2004 and 2005 F-350 Ext Cab |
What is that layer I see in my tote on the bottom? Is that hydrogenated oil or animal fats or both or something from outer space?
thanks nitroman |
Nitroman,
Yes, it is HO, AF and stuff from outer space. I haven't had luck with it, but I haven't tried too hard either. It never separates, so I don't think it's water. My suspicion is that it's mostly animal fats. I haven't been able to even titrate it, so there's the first challenge. Anyone have been luck here? Out in the country where I'm at, I set it out by the woods & it magically evaporates away with the wild animals (& probably some domestics as well). Gotta be careful, I don't want to attract wild hogs, we killed about 12 last year & they can really tear up a field if you don't take them out quick. But it does disappear quickly (coyotes, racoons, birds, possums, bugs, skunks, you name it!). -tony |
take a sample to the oven and heat the snot out of it,, if it clears up and has no popping,, it ain't got water in it. and Its probaly the 3 things you mentioned. which in your climate should be fine for summer fuel. Heat up a sample and titrate it, then do a Dr Pepper method batch from the crappest part of the tote. This will help you figure out how far you want to go with it, weather to make Bio from it or feed the wild life!
I’ll believe global warming is a crisis when the people who say it’s a crisis start acting like it’s a crisis! |
Heat the stuff up. Titrate it. If it is worth the trouble you can make a great summer fuel out of it.
If it is not worth the trouble (in your opinion)clean the stuff out of your tote and give it to Texas Tony. He will lure in some of those Texas sized wild hogs. He will shoot them with the biggest Texas rifle you have ever seen. I will barbecue them and we will eat the meat and turn the fat that renders out into "smoke house biodiesel". |
I like Big Mike's suggestion best...
When do we eat... nitroman |
Making Biodiesel
