PD -not warmer than 68F, or the test could indicate a false pass, I keep the temp of my 3/27 at 64-65f, in hot ambiant temps this is not easy, so soak the sample container in cold water, or start with ice cold methanol (I keep a jar of methanol for 3/27 in the freezer) Tom
" I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005.
| Location: Manitoba Canada | Registered: 24 March 2009 |    |
PD -if your conversion is just on the edge of pass/pail, 5F will have a large effect of pass/fail result, if the process is pushed further to the right, the temp change has little effect Tom
quote: if the process is pushed further to the right, the temp change has little effect
Please explain further?
| Location: Vancouver | Registered: 02 November 2005 |    |
PD -when I complete the single base stage, conversion is at a point that 3ml of bio will desolve in the methanol, but not 4, or 3 ml will desolve but some flakes of amber or white stuff will settle out. So I always push the reaction further with a repo using 10ml methanol and 1grkoh/ltr of oil. after this, 5/27 will be achived, no problem, and the methanol/ bio mix will be perfectly clear Tom
quote: Originally posted by Biotom: PD -when I complete the single base stage, conversion is at a point that 3ml of bio will desolve in the methanol, but not 4, or 3 ml will desolve but some flakes of amber or white stuff will settle out. So I always push the reaction further with a repo using 10ml methanol and 1grkoh/ltr of oil. after this, 5/27 will be achived, no problem, and the methanol/ bio mix will be perfectly clear Tom
Thats very interesting! Do you do that on every batch? Have you tried this with Naoh? I ask this because I have had issues on a reprocess with my entire batch turning to gel using Naoh... Not fun! Jon
| Location: Wellington County, Ontario Canada | Registered: 07 February 2008 |    |
quote: then there really is almost nothing to fall out at any temperature
I disagree. Some fuel I had that tested .09% for FTG would fail around 50f, if I recall. I can look at my notes if anyone wants more details.
| Location: Northern California | Registered: 27 February 2006 |    |
Jon -I switched to KOH 5 years ago for that reason, and have never looked back. Koh biodiesel requires one extra wash, but glop is not an issue. Tom
AT 50F , some high melt temp esters will fall out! Tom
quote: AT 50F , some high melt temp esters will fall out! Tom
Tom - firstly, it seems that there are not much high temp ester in my samples, since they remain clear down to 30f or so. Secondly, have you seen well converted high melting point fuel have fallout on 3/27 at a given temp when the same level of conversion fuel from other feedstock does not? I have not seen this.
quote: Im just speaking from my own experience. If I put my 3/27 in the fridge and its good fuel, it will stay very clear.
If you are passing 3/27 at fridge temp, doing the whole test at that temp (45f), I'd suspect that you are at least 2x under ASTM for glycerides, assuming you wash well. Perhaps you have a need for VERY converted fuel, or you like the comfort of a wide margin for error.
Andrew -this past summer I seen biodiesel made from bacon fat. at amient temp, that day, was 28C there was a white solid layer on the bottom of the sample about 3/16 of an inch thick (high melt temp esters). this biodiesel passed the GC tests. I can just imagine what 3/27 would looked like on that stuff even at 68f.
quote: this biodiesel passed the GC tests.
What were the #'s for mg, dg, tg, total g and free g?
Andrew -I don't know, but they have their own GC machine this was one of many samples on display by the Canaidian International Grains Institute. Tom
Tom, Passing GC with no numbers doesn't really tell us much about how converted the fuel is.
