Both work very well. NaOH sources are 95-98%pure so what you titrate is what you use. KOH is usually 88-95% pure. If you use NaOH to titrate your oil you have to multiply that ammount/liter by 1.4 to get the ammount of KOH to use. I just make my titration solution from the batch of KOH I am using so that my titration number = the ammount of KOH/liter I need + 7.5gm/L for the reaction.
Some have found that their glycerin byproduct turns solid very quickly using NaOH, because NaOH makes hard soap, whereas KOH makes liquid soap keeping the byproduct liquid. Proprietor of The Blunderbuss muzzle loading gun shop. Member of Denver Biodiesel CO-OP. |
I use KOH;
1) its no more expensive where I am than NaOH. 2) The glycerin stays liquid, even after the methanol is removed, so I can continue to pump it and pour it to move it around without having to warm it up. 3) The glycerin stays liquid, so I can leave it in the processor without fear of plugging the pipes. 4) It dissolves faster in methanol. 5) It lets me run a single base stage, if necessary, of higher titrating oil than NaOH can run in a single stage. I've done 9ml oil single stage, just accepting some yield loss. That would be a 6.4ml titration with NaOH, which is well beyond the 5ml limit commonly imposed. |
member 2008 Sponsor |
Take a look at some of these threads.
http://biodiesel.infopop.cc/eve/forums?a=search&reqWord...Type=1&search=Search DD |
It's also more tolerant of water in the reaction.
Dan Sharp 1982 Mercedes 300TD 2001 Dodge Ram 2500 - Cummins Biodiesel |
Hello sharpdan
I have never heard that before. Can you be more specific as to what you mean by more tolerant? Saint Tilly |
Hi Tilly, I haven't done the tests myself, but I have seen reference to it several times related to purity of methanol and a not perfectly dry oil.
The way I understood the posts was that you could have more water with KOH and not affect the reaction as much. Dan Sharp 1982 Mercedes 300TD 2001 Dodge Ram 2500 - Cummins Biodiesel |
Dan,
Makes sense, given that NaOH soap is solid. So, very high soap from KOH = difficult (but doable) wash, very high soap from NaOH = blob O'Jelly! |
so far sure sounds like KOH is what I want to use.
I read somewhere that you can use the glycerin as a fertlizer? I have not seen much about this but that would be very good for me. Do you guys have any more info on that?! ------------------------------ 01 F350 PSD Got 150 gal of WVO and still trying to figure out this whole BioD stuff! |
Try here. Ken |
