Biodiesel & SVO Forums Home
Making Biodiesel
Using Everclear in the place of Heet|
EverClear is ethanol not methanol.
And it has a lot of water in it.
Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
its normally 190proof or 95% pure..but its ethanol not methanol. it would work for titration but isopropyl is cheaper.
-dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 soon a 99 dodge 2500 5.9l 24v..-mine |
Heck I can't remember anything about the last time I used Everclear.
So, if it's ethanol will it not work? I have a gallon of pure methanol to try but after the last trial we want to make sure we don't waste anymore time and product. Does the reciepe change?
I can't get everclear higher than 173 proof. What's yours? Any more than about 2% water makes ethanol almost impossible to use (for biodiesel. |
I'm not sure actually, I just bought it from the liquor store. If we switch to the pure methonal using new oil how many grams of NaOH should I add to my 250mL?
Celina, the recipe is quite different with ethanol than it is for methanol, and it's generally harder to get a reaction. Also, if you don't know the purity of the ethanol, then that really makes things difficult. Stick with the methanol. Kumar Plocher Yokayo Biofuels Fueled for Thought blog .........../ \.............. fueling / R \ evolution since 2001 '''''''''''''/____\''''''''''''''''''' Sustainable Biodiesel... |
$3 a pint for everclear .. $4 a gallon for methanol ... doesnt make sense to use the everclear to me
Trc If you can't dazzel them with brilliance, then baffel them with bullchit. |
Well again, it was a suggestion from a chemist and we'd thought at least it was worth a try. If nothing else we got a good buzz on that night, lol. We can get a good deal on 55-gal drum of straight methanol. So is the reciepe the same using methanol as it is for heet?
Heet is methanol .. 99.5% pure, For test batches it is recomended to get that instead of getting a barrel of methanol right off the bat. Bottle of Heet at walmart .. $4 .. barrel of methanol where ever ya can find it $175 - $350 a barrel. Just for test batches starting out .. easier to find and cheaper total (tho not per gallon).
$4? Is the heet bottle at wal mart bigger than the one at advance auto parts? I just started working at one, and the bottle of heet is $1.88... "When you don't think what you say, you say what you think" Jacinto Benavente. "Wars not make one great" Yoda. WWVhaCwgSSdtIGEgZ2Vlay4gU08gV0hBVD8= |
In case there is any confusion, YELLOW bottle Heet is methanol.
Berny .. I dont know ive not priced Heet out at anyplace. but I know it couldnt be over $4 a bottle.
Wow, thank you...
You got me scared for a moment. Just to make it clear, both Heet (yellow bottle) and IsoHeet (red bottle) are $1.88 at Advance Auto Parts. Obviously, that's still way too expensive for production, but I find it adequate for the first test batches. "When you don't think what you say, you say what you think" Jacinto Benavente. "Wars not make one great" Yoda. WWVhaCwgSSdtIGEgZ2Vlay4gU08gV0hBVD8= |
Sorry, I went to work today, and realized I made a mistake. My apologies to all.
Heet (yellow bottle) is $1.44. IsoHeet (red bottle) is $1.88. In both cases, they're 12 oz bottles. If somebody knows of a place where they'd sell bigger bottles, please post it. "When you don't think what you say, you say what you think" Jacinto Benavente. "Wars not make one great" Yoda. WWVhaCwgSSdtIGEgZ2Vlay4gU08gV0hBVD8= |
Okay, I got a gallon jug of Methanol (ACS Grade) If I used new vege oil do I use the standard 4g of NaOH per 250ml of methanol?
For virgin oil you would use your base amount, the titration is to find out how much above base you need to use with waste oil. Most here say that need 5g/l NaOH as base amount. I have found I need 5.5g/l as base. There are a few that say even 6g/l.
Thanks for the help. We'll try it out and see if it works.
Making Biodiesel
