I certainly am no expert on high titrating oil, but, on these forums there is an acid esterfication section.
question - have you double triple checked this titration? If you want decent yield you will need to use the acid/base process. Please note that it is critical to completely dewater your oil prior to doing this as it will directly impact how effective the acid stage is and/or the added cost (based on the amount of 94%+ pure H2S04 that will be required). If you do not care about yield, then you can do a base stripping step where essentially you take a base and mix it in with your batch and convert FFA's to soap. This will reduce your yield but it is easier and probably cheaper than doing acid/base. |
