Topic Closed|
You may want to consider switching to KOH as a catalyst if you are going to experiment with overloading the lye. Koh is very forgiving and will not solidify in your drain. It requires a little more in volume, so it costs a little more per batch, but it mixes with little or NO EFFORT. Kind of disappears into the methanol. Some stubborn flakes require about four sloshes to dissolve.
I gave up phenol red and penophenowhatsthis for tumeric spice. In your grocers aisle. Did I mention cheap and no shipping, works great, turns from yellow to red? Norman |
That red pool test stuff (phenol red) works just fine for me. Plus I get great dropper bottles from it for a liquid medicine I take every four hours.
2001 Dodge 3500 CTD running B100 Self appointed Minister Of Propaganda, Order Of The Semi Sealed Steel Drum Reactor |
Hello juliena
You misunderstand the reason for the 5% wash at the end of the reaction. The FFA's are already converted into soap, that happens at the begining. The 5% wash just removes a very large portion of the soap that would normally remain in the biodiesel with the glycerine layer. It also releases a small amount of the biodiesel that is bound up with the soap. If enough soap is removed then the soap Jel will not form, but you may have to wash another time or two to remove enough soap to insure there is no jel form. If you use the correct procedure phenol red from the swimming pool shop will work fine. For the easiest method of titrating you can not beat the World Famous Chopstick Titration Techinque (Pat Pend)which contains the correct procedure for using Phenol red, Phenolphthalein and Turmeric as the indicator. I like the colour of turmeric best. Saint Tilly |
Topic Closed
