Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    Methoxide won't transfer
I'm making a 40 gallon batch and I load my methoxide by gravity. Everything is working fine, but I can't get the last half gallon to transfer in. I've checked the check valve, and that's working. I've tried closing the oil valve from the tank, and that worked a little, but the rest won't go. I'm using a standard appleseed processor.
Registered: 24 May 2008Reply With QuoteEdit or Delete MessageReport This Post
Location: Tally, FL | Registered: 07 December 2005Reply With QuoteEdit or Delete MessageReport This Post
I too use an appleseed. Make sure your vent up top is open when you transfer the methoxide in. The vent on the methoxide container open, and then open the valve in front of the check valve slightly to cause a suction...
At least this works for me...maybe I gave you some ideas.
nitroman
Location: Oklahoma | Registered: 01 October 2005Reply With QuoteEdit or Delete MessageReport This Post
Yes, both vents must be open to add methoxide.
If that does not work, it means that your pump is not working, or there is some flaw in your design preventing you pump from creating suction.
Andrew
http://biodieselcommunity.org
03 Dodge 2500 B100 homebrew
79 Rabbit B100 homebrew
