Corresponding pictures.
The settling bio. 3 days from reaction. Can you see the bottom? No heat was used. Purolite and wash test. 1996 K2500 4x4 6.5TD |
These are conversions as posted by Neutral. FFA% = 0.766 x t for titration with 1g NaOH per litre where t is the volume of solution in ml for 1ml oil FFA% = 0.546 x t for titration with 1g KOH per litre neutral doesn't indicate but I would assume it's based on 100% pure catalyst. Here is the link to the thread http://biodiesel.infopop.cc/ev...5159#846105159 As far as the batch in the bubble jug, I would just let it sit as long as you can then run it through your magic beads or pump wash it. |
Hey Brian,
Are you trying to eliminate the water wash? I always use KOH and after my troubles with straight drywashing I have a new system I am using and it works great.. If you mist wash right away you wont get that shampoo you were saying esp if the BD is hot.. Thats just a small emulsion layer that seems to be normal but I have never had a thick 1st wash.. The bubblers creat a bigger emulsion than the mist does in my opinion. I have also filled my sock filter full of woddchips and filled the wash tank through that with good results for less washing.. Now I mist wash, dry and polish with Thermax and do it all in less than 2 days with excellent results.. I dont think I would use anything but KOH.. just my opinion.. If you have a metering pump just trickle it at 4 GPH through the Purolite and it will polish nicely. ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
Double D,
I will certainly read the link and study this method. I could only skim it just now. sounds very helpful. Thank you And yes, Lisa, If PD206 works as directed, and the final tests pass, I could develop an S.O.P. of my own. This oil source is as predictable as yours. I am also studying about reflux column and condenser recovery. I'll then also go with what works most painlessly. I'm completely open to trying new things and methods. I suppose if I had multiple grades of waste oils, I would need to know multiple methods. 'Could happen, ya know. And every process type I've tried so far has furthered my knowledge and experience in this hobby. You have been much help as well. ---------------------------------------------------- Here's an observation; I pulled some of that soap layer from the bottom drain. I put it in a jar next to a jar of it's glycerin. The glycerin is Coca Cola color and the soap is like a ruby red in color. In the sample , the soap was very pale yellow. Odd. I'm attributing this color to further glycerin dropping or amber bio in the soap. Ive seen ruby red glycerin with sodium methylate. It's probly a half inch thick so far in the center of the bottom/top of the poly drum. KOH has been very easy to work with so far. Batch 3 on the K. --------------------------------------------------------- I'll be back on the 8th of July. The reaction will be 11 days old. I'm leaving the low amp fan on until I leave. Thanks for the replies, very encouraging. Brian 1996 K2500 4x4 6.5TD |
Sounds interesting.. I'll watch your progress..
I just wont do the entire drywash thing right now after my troubles with my truck.. If I had time to let it settle days on end and all that I would but just easier to water wash a bit and move on for me.. plus the results are great so I'm gonna stick with it.. However I do sooo wish I could just process and drywash... life would be so much easier.. My 1/2 layer in the wash tank is always yellow.. I just thought this was the soapy emulsion layer.. Now when my truck got screwed up because of the soap fallout after demeth it was ruby red.. my guess is your bubbling is demething it and so you are getting the KOH soap fallout.. my glycerin is also a dark amber.. sound like you have all 3.. Have a good vacation and your goodies will be there when you get back.. Lisa ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
Hey,
Ya, Im sure it's methanol free or close to it. In another week it ought to be. The beauty is that if the resin fails to reach spec, I am equipped to mist wash it after. But. I also read that resin can raise your acid number. Who wants that? Everything else can be on spec and the acid fall short. Would combining wash methods do this? hmm. Let's find out! Brian 1996 K2500 4x4 6.5TD |
Thats what I do.. combine them.. I guess combine them.. Wash/dry then resin dry wash.
You saw my last numbers.. the acid was okay. May sure you settle long enough. Once your demethed if all that ruby red soap has not dropped out it will waste your resin in 1 batch... did mine and it took 10 gallons of meth to clean it. My method now with misting 1st should make my resin last a really long time! ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
This commercial producer near me (I took the photos) uses ONLY wood chips to purify his biodiesel. Now as soons as I can stop procrastinating I will set up a chip tank in front of my resin lead/lag tanks as a sort of prefilter to extend resin life. I haven't used a drop of water for a year now, except a little recylcled stuff for the methanol recovery condenser.
The biodiesel still has to be demethed, which makes it easier to extract any suspended glycerine. The stuff you get on the bottom of the tank after demething is just that, suspended glycerine that has fallen out of solution. HTH **My reactor/processor :B100WH.com **The Colaborative Biodiesel Tutorial **B100 Heated Winter System ** Biodiesel Glycerine Soap - Make & sell soap from Biodiesel Glycerine |
Yeah I think we have learned that lesson. Problem is it seemed to take days to settle it all out and I dont have room or time for more settle tanks.. I also thought the resin would get any leftover soap and in my case it did not.. but it did make my resin useless in 1 batch..
The problem I have been having with the woodchips it seems great on the first pass, but the next batch I run through it will actually put the last batches soap back in just a bit. If I water wash after the woodchips, the wash water is almost a lime green.. very weird.. My pvc tower didnt stand up to the BD so if I can build another tower I may try again but for now.. I like the way I am doing it.. Thats a great setup they have going on! ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
Hi Legal,
I remember when you posted that about RolfQuo. I was following the whole woodchip discussion. My problem is finding a reliable source of cheap hardwoods. I looked around. And am still open to it if I find some. The first thing I was told about making bio is 'Time, Temperature, and Gravity'. The second thing was 'Water is not your friend'. If I can stop misting all together, I will. I never did the 5% prewash. Thanks for the reply! ------------------------------------------------------------------ Lisa, I guess I dont use as much fuel as some folks. I'm pretty far ahead now. That's why I can experiment with other things. This is just my first season making full batches. When I find what I'm going to be comfortable with and all my equipment is built, probly by next summer, I will have a routine. I'm enjoying the learning so far. Time and space- Time, I have. Space, well, that's another, sad story. I'm still in town with a small garage. I can keep things like chemicals and feedstock at work. If I had everything I've gathered for bio at home, I would surely get some kind of citation. I want the soap titration kit, I only need the Bromo Blue, so long as the HCL can have balm inhibiter in it. Thanks for checking up on me. -------------------------------------------------------------------- This morning I ran the QTA on the bio. Here are the results. TG .07% Good Acid .2% Good Cloud 0*Celsius Good FG .024% ASTM is .2 H2O .069% ASTM is .05 MeOH .08 Good .20 is passing I have demethed in a few days using only a bubbler at ambient temp. Yield is 100%. A quick edit to my first post; it's 132 liters, not 32. More like 34 gallons. I'm still using the little processor. The one in construction will put out 55 gallon batches. Cant mist wash 55 gallons in this type of settling tank, but I can settle it. I'll need to make up another so I can do 110 gallons in a weekend, transfer to a tote and begin polishing @ 5gph~. How dose that sound? Thanks for the support, guys. Now I need to read up what Double D has helped me with. Brian 1996 K2500 4x4 6.5TD |
Hi Biogirl, is there any reason why you don't do a 5% prewash instead of a mist wash before drying then sending thru the resin? I did a 5% prewash yesterday to experiment with the quality as Im moving over to dry wash.. After settling for 2 hours after the 5% pre, I had 0.7% water, and 1200ppm soaps. Seems 5% prewash is still not effective way to reduce soaps to 500ppm the reccomended amount before shooting thru the resin beds. Wonder if mist would do a better job... |
thats exactly why.. It doesnt get enough out. PLus I dont like having a little bit of wet oil left in the processor. I just decided after building the continuous drain and I didnt have to babaysit that it was easier than prewash. PLus the lady I give the glycerin to appreciates it..
Also, before you can send it to the drywash after prewash you would have to dry and demeth which we all know I learned the hard way causes slow soap fallout and longer settling times. By mist washing I get all the methanol out that way and the soaps are washed out at the same time.. My resin should last forever this way.. my fuel is actaully ready after drying but I polish it anyways just to make it that much better.. I have gotten some great fuel results with this method so I am just gonna stick with it for now even though I really wanted to get away from water washing.. catch 22! ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
Definitely! I think if ya wanted to do strictly dry wash your methanol recovery system has to be top notch with vac set up and all the rest, to get the meth content low enough for soaps to fall out in reasonable time. Letting settle for days on end just doesn't seem practical for most who go thru a fair bit of fuel.. |
I agree... my buddy is still using just the drywash but I dont want to mess with the goo in the bottom of the drytank, processor and settle tanks on top of the settling time.. uuggh
I'll be home tomorow night.
I'm hoping gooey is all it will be after settling so long. I hear of folks settling several batches before cleaning it out. I'm wondering how easy a mistwashing will be by then. I'll do a small sample and see. I can switch to NaOH 99%pp if I choose to keep doing it this way. And the new processor tank is dome topped wich I can vacum methanol out easier with. Both should speed things up if I understand correctly. Brian 1996 K2500 4x4 6.5TD |
Yeah I didnt even consider switching to NAOH just to use my drywash...
I dont want to clean that goo at all. Did it once and thats enough.. Eevn with a standpipe I dont like it down there.. ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
Ok, I'm home now and the batch has set for 8 days.
It looks real good and clear to the bottom. Very vivid. The 'goo' is very thin at the bottom, maybe a half gallon or less. I see ruby red (glycerin) color. If I used the standpipe, there would still be 5 gallons of good fuel in the tank. So... If this process works for me, I could essentially do 10 batches before needing to use the bottom drain. That's a full tote of fuel. But with one tank, it will take 10 weeks. I'd need another or 2 more at my pace. Question there is, Will this goo remain flow-able, or will it set up hard? I'll re-test everything tomorrow, I've been on the road for 10 hours today. Brian 1996 K2500 4x4 6.5TD |
The "goo" I had stayed flow-able.. its just gooey. I emptied my tanks and then used my sucker to suck it over the bottom.. Flushed with BD that I drained back into the wash tank and did it again..
Sounds like a good system.. ![]() Lisa 2006 Ford F250 6.0L Powerstroke with 12 inch lift |
