Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Making Biodiesel    Waste Water. Where does it go?
Not enough total amount of water to wash 35 gallons. Just my opinion but I would use a total of more than 20 gallons. Wash till the drain water is mostly clear. Lots of opinions on this but I wash and wash more. Might be overkill but it is my motor that is going to use it. Water is cheap and motors aren't.
2001 Dodge 3500 CTD running B100
Self appointed Minister Of Propaganda, Order Of The Semi Sealed Steel Drum Reactor
Originally posted by emiperformance:
What if you are on well and septic?
Will it harm your septic tank?
My WAG would be no way in hell. The natural metabolic processes of the bacteria in your septic make by products that are way nastier, and as has been pointed out methanol actually encourages bacteria by feeding it. The small amount that'll make it to your tank from your wash water isn't going to harm anything.
Registered: 12 June 2006Reply With QuoteEdit or Delete MessageReport This Post
I dont know, but suspect that you could kill off all the bacteria in your septic tank if you process a lot of Biodiesel. Small amounts are ok -- it is like small amounts of Drano. Smile Just be careful you dont put "too much" whatever that is...
Chris
Location: Mechanicsville, VA | Registered: 30 May 2006Reply With QuoteEdit or Delete MessageReport This Post
