Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Making Biodiesel    How I blasted a nasty emulsion into clear separation in 30 seconds
I'm sure that some of you will frown on this but I'm posting it anyway.
I've got very very soft water where I live so water washing is a pain.
I regularly get nasty emulsions even in the 4th and 5th wash. I'm dumping in hot water and mixing with a drill and paddle to stir aggressively.
I've done this twice now. I've got some muriatic acid laying around that I bought at Lowe's. It's cheap. I filled up a 5 gallon bucket with 3 gallons of hot tap water and spiked it with a very small amount of the muriatic acid. I dumped it onto a nasty looking emulsion, stirred with the drill and BOOM! It separated instantly.
Location: Little Elm, TX | Registered: December 12, 2007Reply With QuoteReport This Post
pwr.
-ya it works, so does sulfuric acid and the one I use vinigar at the rate of 7ml/ltr of wash water. For sure soft water can be a pain, but the emulsions can be minamized by reducing the amount of water you use in each wash. since I started doing the 5% wash for each wash, I have not had 1 emulsion. Warning: it will take more washes, but a complete wash cycle is only one hr, (pump washing) Pump for two minutes and settle, drain , repeat. Two minute wash is for a 160ltr batch. Tom
The 5% pre-wash took care of my immulsion problems. Wouldn't think of not doing it now.
If you've got room in your reactor, I'd give pre-washing a try.
Registered: July 19, 2008Reply With QuoteReport This Post
When I ended up with super softened water I was happy to move over to resin purification. That said though, heavy salt works wonders as well (but then, like acid, you have to wash it out).
My next upgrade is to oak shaving drywash. I just need a design that I can build. I'll be starting with 55 gallon drum.
I would think that if you fill a 55 gallon barrel about 1/2 full of hardwood shavings and sprinkle the biodiesel over the top of the shavings and slowly release the biodiesel out one of the bungs with a ball valve adjusted to a trickle that you would probably be near ready for the tank. This method is so easy that even a caveman can do it. Eek
I prefer to allow the biodiesel to settle via gravity and time prior to the shavings.
Location: Chambodia | Registered: December 31, 2007Reply With QuoteReport This Post
