Right on Sparky.
NaOH based byproduct WILL turn into a solid at room temperature if you leave it long enough. So, in future, make sure you drain the byproduct before everything cools off.
Mine goes straight into the tank of the still for de-mething. You will remove the methanol thoroughly and completely before turning it into soap, right??? Finest regards, troy |
Actually, it started to gel before it had even set long enough to fully separate.
Once I got it heated up, the glycerin melted. I continued to mix everything for a few hours, and today I was able to drain off the glycerin. Thanks guys! Yes, I do plan to demeth before making soap. |
