Sponsors    Home    Forums  Hop To Forum Categories  Cold Weather Biodiesel    -67 "Permaflow" Cold Flow Biodiesel??
From what I can gather, this Permaflow cold weather biodiesel is an additonal process added to the production of biodiesel and claims to prevent B100 from gelling all the way down to -67F for less 10 cents a gallon. Anyone heard of this? Seems too good to be true…
This message has been edited. Last edited by: Craig1565,
Registered: 17 June 2009Reply With QuoteEdit or Delete MessageReport This Post
turnerbiodiesel.com
http://www.greencarcongress.co...cold-weather-te.html This is a good link
www.turnerbiodiesel.com
www.turnerindustriesinc.com
Metal Fabrication and BioDiesel Products. Dry Wash Towers,Processors,Home Heating,Centrifuges,Cold Clear.
Location: Chippewa Falls WI | Registered: 24 March 2009Reply With QuoteEdit or Delete MessageReport This Post
That is a good link, at the bottom of the page you can download a PDF and on page 16 it shows a little diagram of the process: http://www.purdue.edu/dp/energ...007%20symposiuim.pdf
it likely is too good to be true and some petroleum lobby will likely buy up the patent for millions and it will never come to market
I'm surprised this isn't getting more attention. It seems to solve a BIG problem with biodiesel.
I have found a good deal of information on the process. It seems that it is actually pretty darn easy and uses commonly available materials. You can even reuse the Urea over and over to separate the saturated and unsaturated biodiesel molecules. You can then re-blend to the temp range you need, as -60F is a little extreme for most.
Location: Southwest Colorado | Registered: 22 November 2009Reply With QuoteEdit or Delete MessageReport This Post
Nothing is said about anybody having made any actual fuel with this process, it's often a long, long way from theory to finished product.
Well, actually a lot was said last winter when they did tests with the Permaflow fuel in Fairbanks Alaska. Do a Google search on those keywords to learn more. This is a proven product.
'89 Toyota 3.4L TDI + FPHE
BD+ULSD+VO+JetB blends
