Read-Only Topic|
First be sure to separate the as much water as possible from the BD using a stand pipe drain from above the water. Don't forget to drain water in drain before pumping into drying tank.
The way I dry is pump from the bottom of the tank and diffuse into a curtain of oil. I use a small fan to blow around the oil and move the water vapor out and blow in dryer air. I can speed the process by adding heat. |
The way i dry my Bio, is after washing had to my drying tank heat up to 75deg and pump around for afew hours.
This message has been edited. Last edited by: Shaun, pict0278_copy.jpg (26 KB, 92 downloads) |
Read-Only Topic
