Read-Only Topic|
By the way, the oil titration result was very low, I used 1mL of the NaOH titration solution (tried 3 times, same result).
I got the WVO from a school restaurant, I believe they have strict rules about how they should use their oil. |
lk: do you have a means to circulate the bd? It won't dry by just sitting - the water-laden part sinks to the bottom, away from the air. It can be "bubble-dried". Is the container wide-open to the air? I've proven to myself that a 1-gallon glass jug won't dry bd without a bubbler. Even an open top 55-gallon drum won't dry a load of wet bd without circulation.
Well, I've read somewhere that settling washed biodiesel in an open container should dry it in a week or so. Apparently, this was wrong.
To circulate I could use my mixing pump, but 800W electrical consumption and 3600L/h are a bit violent and energy-consuming (it's otherwise very good at mixing methoxide within a dozen minutes So I think the best thing to do then is to get myself an aquarium air bubbler, which I need for easy washing anyway. |
glycerol solidifying in the processor is a nightmare ive encountered twice and now take steps to avoid. Make sure you drain it before it gets cold. there will always be some residual glycerol dropping out for 12 hours or so afterwards, but that hasnt bothered me so far.. the heat in the biodiesel seems to stop it from going solid. If all the glycerol is left the stuff sitting in the pipes and at the bottom of the tank will go cold and harden into something like rubber.
Hi, I use two air bubblers to dry my 80 litre batchs of Bio, usually takes two days then its crystal clear.
This message has been edited. Last edited by: Shaun, pict0134_copy.jpg (34 KB, 130 downloads) |
You guys are well behind. I use a clear water pump and spray dry my Biodiesel and I can usually get it dried in about 8-10 hours or less depending on Humidity. I am looking into using a dehumidifier on high humidity days. Also, I have bubbled it all day and this helps cut time off the spraying. I am going to try to attach an image of my sprayer.
This message has been edited. Last edited by: Shaun, Amazing how something so simple can be so easily overlooked. BDpic10150718_copy.jpg (31 KB, 209 downloads) |
Here is another image. Wish there was a way to attach multiple images.
This message has been edited. Last edited by: Shaun, Amazing how something so simple can be so easily overlooked. BDpic1015075_copy.jpg (38 KB, 191 downloads) |
Nevertheless, I gave my batch one more wash and then used an air bubbler I bought for 10 euros on Ebay - after a dozen hours, it went crystal clear
You're certainly right about spraying, but it requires more room, equipment and energy. Thanks ! |
I circulate with a 1 gpm 12v pump onto the side of the drum, with a fan pointed at it. If the fuel is well washed, it will dry in a few hours this way, depending on humidity. More complete washing = easier drying. |
Read-Only Topic
