Sponsors    Home    Forums  Hop To Forum Categories  Mercedes    Swapping 5cyl. MB diesel into 1986 Jeep Cherokee
Hey all,
I am swapping out the Renault 2.1L that is currently in my 1986 Jeep Cherokee for a 5 cyl. MB diesel. I'm all set on the engine, and can mate it to a manual transmission from another MB, but I will lose the 4WD if I do so. I was wondering if there was any way to maintain 4WD capabilities? Will the 617a mate up to an older G-series transmission...or a UniMog...or...? Cost is an issue, of course, so I'm looking for a reliable yet cost-effective solution. If I have to go to 2WD, then I'm willing to make that concession, but it would be great to keep it 4WD if I can.
Should I be posting this in the Misc. forum?
Thanks.
Location: Pasadena, CA | Registered: 18 May 2006Reply With QuoteEdit or Delete MessageReport This Post
Somewhere I heard of adapters for Jeep swaps.
126 diesels yahoo groups
83 SD straight exhaust 94 Cobra
Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost
0-60 10.8, 37 mpg highest
2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer.
Check out this thread- om617 into a 4runner
Different vehicle, of course, but he shows that it's fairly simple to make an adapter.
When I find a donor engine, I'm going to try and do this in our TJ with an AX-15.
Check out the rest of that forum- great info there!
Hope that helps,
Los
Location: San Antonio, Tx | Registered: 12 May 2009Reply With QuoteEdit or Delete MessageReport This Post
Also, www.4x4labs.com supposedly has an adapter for Chevy transmissions, but it's $1k!!!
See if there is the option of running a divorced transfer case. This way you can pick and chose what ratios you want in the transfer case with out having it physically attached to the transmission.
Illegitimi Non Carborundum
