Does anybody know what kind of injection system does this car, a 1987 300 TD 6 cyl., have? Thanks, | ||
The W124 chassis 300D (pre E Class facelift) has the OM603 engine, which is a 3.0 litre six-cylinder turbocharged engine that appeared for one year only, 1987. The Turbo Diesel W124 appeared anew in 1990 until 1993, as the 300D 2.5 Turbo, with the OM602 engine. The latter engine was a 2.5 litre five cylinder turbocharged engine. The OM603 engine family was a straight-6 Diesel automobile engine from Mercedes-Benz used from 1986 through 1994. The engine has a capacity of 2996cc and in many respects the engine is similar to the OM617 engine. Version 603.960 is turbocharged; the others are naturally aspirated. The camshafts and injection pump are driven by duplex chain from the crankshaft. A separate single row chain drives the oil pump. The camshaft operated the valves via hydraulic bucket tappets; valve clearance adjustment is automatic. Fuel injection is indirect. A Bosch PES in-line injection pump is used, with a mechanical governor and and vacuum-operated stop control. The pump is lubricated by a connection to the engine oil circulation and the fuel lift pump is mounted on the side of the injection pump. Preheating is by glow plugs with automatic control of preheating time. http://en.wikipedia.org/wiki/Mercedes-Benz_300D http://en.wikipedia.org/wiki/Mercedes-Benz_OM603 | |||
It may be that in the US the only year that the 603.960 was available was 1987 but in other parts of the world there is more variation. I have a 91 300D from Japan which has that engine in it. Cheers Dan | |||
I wonder what the differences are between: 603.960 603.961 603.970 daw (also known as daw_two on some forums) 1987 Mercedes 300SDL 2000 diesel Dodge Dakota Cummins ![]() 1984 Mercedes 300D 1981 Mercedes 300D | |||
603.960--2996CC base engine--for 124 chassis- 300D Turbo, 300TD Turbo(87) 603.961--2996cc base engine--for 126 chassis- 300SDL (86-87) 603.970--3496cc base engine--for 126 chassie- 350SDL (90-91) 140 Chassis (92-94) | |||
Robert Bosch mechanical--recirculation style injectors, last rendition of non CDI rail injection systems for mercedes. Introduced in 1984 on the 201.122 for the OM60X series engines and last used in 2000 in various non us models on the 605 and 606 engines. Last US application (96-99 E300D and E300DT) | |||
Between the .96X, very little, the .97x was .5L larger and had bendable connecting rods. Oops. | |||
Hello i also own 87 mercedes looking for some help on replacing glow plugs in my car can you help. | |||
Powered by Social Strata |
