quote: Originally posted by freesoul: No, he claimed it was mixing it with something not high heat.
Then he's got some vegetable oil/gasoline/kerosene blended with WMO....and probably the secrete deezel snake oil. "Cracking" is a high temperature process.
Then he's not cracking it. He'll be diluting it with some hydrocarbon thinner like toluene or something and filtering it. Possibly low grade cellulose paint thinners they use for washing out spray guns in body shops.
You mean salt cracking.I've heard that works with salt rock and drill motor mixer.They offered it for wvo,but I tasted the result and it was salty.Old engine and trans oil might be different.
126 diesels yahoo groups 83 SD straight exhaust 94 Cobra Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost 0-60 10.8, 37 mpg highest 2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer.
| Location: Bristol Tennessee | Registered: 05 January 2008 |    |
