Home
Forums
General Energy Discussion
A big CAUTION if intending to use E85 in a 2-stroke engine|
That's not the only problem with ethanol blends, if the fuel gets moisture in it which is more likely because of the ethanol, the ethanol water mix separates from the hydrocarbons.
Most model airplane fuels use synthetic oil. Castor oil hasn't been popular since the 1960's or so. The synthetics don't leave the deposits that Castor oil did. Note also that the Castor oil used in fuel isn't the same as the castor oil sold in drugstores. Some motorcycle shops still sell castor oil, preferred by some old 2-stroke customers.
The oils that ARE used in model fuel may not be the same as Walmart Blue 2-stroke oil. It might be worth researching it more. I've read in other threads that E85 (and even straight ethanol mixed with gasoline) will drop it's lubricant load when the ethanol absorbs enough water. If true, then the trick is to keep the fuel "dry" in storage and use. Alternatively, a lubricant is needed that stays in solution even if "wet". Perhaps that's what model airplane fuel uses? Cheers, JohnO |
Does biodiesel provide enough lubricity for a 2-stroke? It may not separate out as readily.
'05 CRD B100 '01 TDi B100 '83 240D B100 |
Home
Forums
