Closed Topic Closed
Does anyone here have a link to a site about methane gas generators? Perhaps something similar to Collaborative Biodiesel tutorial. I want to get my feet wet..not be intimidated.
Hi!~
Location: Charleston, WV | Registered: 19 August 2005Edit or Delete MessageReport This Post
Look 4 posts down on thisforum.
Location: fisher,illinois,usa | Registered: 03 June 2003Edit or Delete MessageReport This Post
Look 4 posts down on this forum.
That really didn't help....WASTE GAS...as in the gas namely methane released from human and animal waste.
Hi!~
dva
Doobie Ex,
go to the top of the page. Click on FIND. Un-tick the 'search current forum only' box. Type METHANE into the query box.
This gives over 200 hits that refer to methane on this site. It's up to you to sort them. Have fun
regards
dva
Location: Yorks,England | Registered: 30 June 2001Edit or Delete MessageReport This Post
Closed Topic Closed
