Biodiesel & SVO Home
Biodiesel & SVO Forums
General Energy Discussion
Best way to heat home?|
member 2008 Sponsor |
I use a 30,000btu vent free natural gas heater from Northern Tools and haven't used my central heat since. I live in a loft apartment with a large living area open to the kitchen. There is no heating in the bedroom but I kind of like it cool like that.
I figured the savings using gas vs. electric central heat paid for the heater in one season. 2002 F-250, 7.3l PSD on grease since 2004 |
Natural Gas and Propane are clean enough burning that they can safely be used without a chimney. I'm not quite sure what the limits are, but rather than sending the heat up the chimney, they are "vent-free", and 100% of the heat stays inside the house. It is not recommended for most other fuels such as wood. |
Not true, and anyone doing that is compromising their health and that of their family.
Personally I would not use a vent free device but that is me. The Rinnai 1004 is direct vented. It has a tiny little 3" horizontal exhaust (half of that is the intake) and you install it on an outside wall.
I'm no expert, but if they are running PERFECTLY, you just have to consider the significant addition of moisture they will add to your home. But there's no such thing as perfect, so the better your house is sealed up, the more risk you are assuming. In an ice shanty out on a lake somewhere, they would work great, as the whole structure is vented every time the door is opened, but otherwise... |
I think you would actually get better luck running your fans on forward since the ducts are in the ceiling...I think running them in reverse (despite the manufacturer suggestion to do so in the winter) is creating a back pressure that the furnace has to overcome.
If its hot to the touch, you need to insulate that ductwork and furnace surface until it isn't even warm to the touch. If its in an unheated attic, ice should be able to form on the outside of your ductwork insulation on a cold enough day, otherwise its not insulated enough. |
I agree. The attic should be cold! but alas I purchased the Rinnai already. We are going to work with that and shut off the attic furnace and see what happens. I have a feeling we will be warmer for less money but time will tell.
