Read-Only Topic|
You got it exactly. The heated oil remains at about 135 degrees for the duration of the mixing cycle to provide ideal conditions for the process to work. Pumping out of a bottom draw and just pumping back into the top of the processor is the common way to achieve circulation. Some stir the batch, just remember that you need to be fairly well sealed, as you will create some nasty vapors.
One word to the wise--set up your system so that the methoxide is introduced just in front of the circulation pump. The violent thrashing that the impeller in the pump provides mixes the two very well and gets the reaction started right there in the pump. Norman |
Read-Only Topic
